H22, a/c in eg question?
Old Apr 15, 2003 | 08:07 AM
~~~InNeEdFoRsPeEd~~~'s Avatar
* B A N N E D *
Default H22, a/c in eg question?
any of you h22 guys know if it will be more difficult to install a/c system after the engine is in? if so, how much difficulties? TIA
Old Apr 15, 2003 | 08:22 AM
V8SHME8's Avatar
Default Re: H22, a/c in eg question? (~~~InNeEdFoRsPeEd~~~)
http://www.inlinefour.com makes an AC compressor bracket so you can use the compressor off a D series. If you still have your evaporator and condenser, then it will be no problem.
Old Apr 15, 2003 | 08:59 AM
* B A N N E D *
Default Re: H22, a/c in eg question? (V8SHME8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V8SHME8 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.inlinefour.com makes an AC compressor bracket so you can use the compressor off a D series. If you still have your evaporator and condenser, then it will be no problem. </TD></TR></TABLE>
I know about the bracket, but what I wanted to know is when I have the motor already in, and wanted to install the whole a/c system all the lines and all, will it be very hard to do this with the motor already in?
Old Apr 15, 2003 | 09:05 AM
Jonathan_ED3's Avatar
does inline four actually make it, or just sell it?
As far as i knew only HCP made a bracket at the current time.
Old Apr 15, 2003 | 10:03 AM
* B A N N E D *
Default Re: H22, a/c in eg question? (hot_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EG &raquo;</TD></TR><TR><TD CLASS="quote">does inline four actually make it, or just sell it?
As far as i knew only HCP made a bracket at the current time.</TD></TR></TABLE>
I'm sure they sell the HCP mounts only...
Old Apr 15, 2003 | 11:11 AM
Newman's Avatar
New User
Yes, InlineFour carries HCP mounts.
Here's a couple of picts I have up on our website:
Fits in there just fine. Can be a tight fit, but when you get it working, it's nice during the hot weather. The AC belt that you need to use is the Dayco 420K4 belt (same thing as the Goodyear Gator-back 4040410 belt)
slowsleeper
Jun 6, 2006 06:54 AM
bigxclumzy
May 19, 2006 03:40 PM
eg6madness
May 5, 2006 06:02 AM
nikolai.
Feb 28, 2006 02:04 PM
