The official Expo3 owned by brake problems thread
So how many of you warped your rotors? I am using Endless CCX on all four corners and on the way to the expo, I felt a tad of shaking when I press the break at high speed. But unexpectly, these Autozone rotors gave out 3 laps on first day's first session.
So I traded off the 2nd session by searching for tools and put on the new brembo blanks from Colletti
After I embeded them, I ran the 3rd session with satisfactory breaking.
After sunday's first session, the brake start to feel mushy. So again, I sat on the 2nd session drainning out the old Motul brake fluid and clutch fluid and replace them with ATE superblues. Well, the pedals are not firm, but once I am out on the track in the 3rd session, the brembos rotors gave out again after 5 hot laps. Once I am back to the pits, my front brake are sm0king with tiny flames!!
And I wasn't even breaking that hard as I tried to drive smooth throughout the event. I brake at the 150 in the front straight and the 3 cones mark at the uphill. There is no way that I am over using these brakes.
What is the problem here that I went through 2 sets of rotor with merely 60 minutes of track time? Should I resurface the CCX? What is a good rotor to go with agressive pads that can last me more than one event?
After I embeded them, I ran the 3rd session with satisfactory breaking. After sunday's first session, the brake start to feel mushy. So again, I sat on the 2nd session drainning out the old Motul brake fluid and clutch fluid and replace them with ATE superblues. Well, the pedals are not firm, but once I am out on the track in the 3rd session, the brembos rotors gave out again after 5 hot laps. Once I am back to the pits, my front brake are sm0king with tiny flames!!
THIS IS CHAD....
the only brake problems i had this weekend were when i was in someone else's car.....usually with stock pads and fluid.....i think i cooked at least 4 stock ITR pads and fluid in bout 3 laps....
jason (kit kat)'s r is by far the fastest r i have driven....but with stock pads braking became an issue when i was at 133 on the back straight braking at the 2 cones!!!!
Ray-
I can't imagine that you went through 2 sets of rotors due to track dedicated pads!
Maybe it's got something to do with your calipers? It might need rebuilding, who knows. Get some legend calipers or SpOOm calipers.
I was running on Cobalt GT-Sport (which btw was awesome) with stock rotors + ATE superblude, and it felt great for the most part. Never warped my rotors (stock). The pedal felt a bit mush after the second session on day 1 due to usage, but that's about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FAST4DR »</TD></TR><TR><TD CLASS="quote">jason (kit kat)'s r is by far the fastest r i have driven....but with stock pads braking became an issue when i was at 133 on the back straight braking at the 2 cones!!!!</TD></TR></TABLE>
Setup?
Setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason Franza »</TD></TR><TR><TD CLASS="quote">Setup?</TD></TR></TABLE>Fast.
I was told by my instructor, who is not an H-T person, that I had warped rotors (Very badly warped rotors he said, that's a quote) after the 5th lap on the first day. I had a violent shudder in the steering rack and the car was noticeably wiggling. Very scary when you have that shudder at 115mph and you need to stop and stop fast.
I was running Cobalt GT-R v-spec VR in front and cobalt rotors.
I found Trey, who I then went for a walk with the look for Andie. From about 50 feet away, Andie says "That's a film transfer, I'll take your car out with you and re-bed the pads". So much for 'very badly warped rotors'.
We did about Fifteen 90/100 mph stops on PA Route 18. I'm not sure how slow we got after each brake, probably 40-50. After 15 stops, not getting enough sleep and not feeling all that well, I was very very naseuous.
Anyhoo... BIG GIANT THANKS to Andie for helping me re-bed my pads. Didn't miss a lap and got to talk to Andie for about 45 minutes while we talked about what had happened and while we re-bed the pads.
BTW - the pads were amazing... no fade, good cold, Awesome when hot. Amazing Pads!!
I probably took off a good 40% of my pads.
My instructor Corey stated, if the car isn't humping with ABS, you aren't pressing the brakes hard enough. Slam on those bitches.
Re-Bed with new rotors or the current shaking ones?
Previously, I've done 3 60-30 brakes and 3 other 80-40 brakes...I did them pretty hard as the tires locked up and skid.
You can either have the rotors cut to get rid of the junk on them, or just call it a day and go with a new setup which won't leave so much uneven deposits on the rotor.
Warren
Warren
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren »</TD></TR><TR><TD CLASS="quote">You can either have the rotors cut to get rid of the junk on them, or just call it a day and go with a new setup which won't leave so much uneven deposits on the rotor.
Warren</TD></TR></TABLE>
Or just sandpaper them down a little, worked great for me..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nEoMuGen »</TD></TR><TR><TD CLASS="quote">Re-Bed with new rotors or the current shaking ones?
Previously, I've done 3 60-30 brakes and 3 other 80-40 brakes...I did them pretty hard as the tires locked up and skid.</TD></TR></TABLE>
I did the same thing, except I did 6 passes from 60 or so to 15, then 6 more with harder pressure.
On the 5th lap I had what was thought to be warped rotors. I was stabbing at the brake and not being smooth, and caused the pads to leave a film several places on the rotors.
Andie took me out and we re-bedded them at much higher speeds, upwards of 100mph. He was at the threshold also, and we did about 15 brakes in a very short time span. I let them sit for the next few hours (except when we went out on track for the shots at lunch on saturday) and had zero problems after that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren »</TD></TR><TR><TD CLASS="quote">It's not the rotors. It's the pads.</TD></TR></TABLE>
It's not the rotors or the pads, and the rotors aren't warping. Andie is right - it's film transfer.
Read more here.
BTW I'm using Endless CC-X pads (great pads BTW) and I get 6-8 track events per set of slotted two-piece Stoptech rotors.
Read more here.
I believe I was sitting in your car in the last session on Sunday. I remember your car was having a little "shake" under braking. I don't think they are too bad.
I will take some ppl advice to re-bed the pad or resurface the rotor since they're brand new.
btw.....I had similar brake issue on Saturday but after replace the 3 weeks old rotor with a set of aged old brembo given free from Aaron.......my brake work prefect.
I still not sure what to cause the "shake" in my rotor.....but i "think" it may have something to do with bed-in or even the way I hit the brake. More research will come.
Mine were great. Stock rotors with 40k on them, Cobalt GT-R Spec VR front, stock rears, with freash Super Blue Fluid. Big thanks to Andie on the choice of pads, which grabbed hard all weekend, and had no signs of fading.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhosITR »</TD></TR><TR><TD CLASS="quote">I will take some ppl advice to re-bed the pad or resurface the rotor since they're brand new.</TD></TR></TABLE>
Just remember that resurfacing the rotor will make them even more susceptible to shudder, so don't be surprised if it comes back very quickly at your next track event.
sierrahiker8
16
Sep 12, 2012 06:41 AM
