gsr block question...84mm
Old Apr 14, 2003 | 06:02 PM
trbo823's Avatar
Default gsr block question...84mm
im getting my gsr block sleeved and was wondering if boring it to 84mm is worth it or a good idea...its gona be a all motor setup...any suggestions would be great or if u have done this set up how is it....thanks
Old Apr 14, 2003 | 06:59 PM
AllmotorJunkie's Avatar
Default Re: gsr block question...84mm (trbo823)
84 mm is fine. I don't see any problem with that. IMO if you are sleeving...then yes you should make your cylinder bigger...Its like getting two things done for the price of one.
My homie sleeved his GSR block to 85 mm. I think (correct me I wrong) that 86mm is the largest you can go.
Old Apr 14, 2003 | 07:01 PM
PhatOptimo's Avatar
Default Re: gsr block question...84mm (AllmotorJunkie)
add a deck plate while your at it.
Old Apr 14, 2003 | 07:06 PM
jdmDXrex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllmotorJunkie &raquo;</TD></TR><TR><TD CLASS="quote">84 mm is fine. I don't see any problem with that. IMO if you are sleeving...then yes you should make your cylinder bigger...Its like getting two things done for the price of one.
My homie sleeved his GSR block to 85 mm. I think (correct me I wrong) that 86mm is the largest you can go. </TD></TR></TABLE>
everything sounds good.... just wanted to add that if this is a street car go 12.0:1 and if its an all race motor go a lot higher, port the head, big injectors, crazy cams and tuning and you got a bad *** motor.
PS deck plate and custom crank would be bad *** too
Old Apr 14, 2003 | 07:33 PM
trbo823's Avatar
Default Re: gsr block question...84mm (jdmDXrex)
sounds good..thanks for ur replies...others?
Old Apr 14, 2003 | 07:35 PM
Kataku2K3's Avatar
Wanna go crazy??? I would say **** the deck plate/stroker motor... Send the block out to GE.. have them offset, o-ring, and sleeve the block up to 89mm's... The drop a B18A/B/20B/Z 89mm crank into it with custom pistons with that wristpin moved up... 13.50:1??? You can tune that out on 92... RACE MOTOR 15.0:1+ Actually the B18C crank will be fine... I was just figuring for more displacement and the 1.58R/S is cool... Perfect for me ='s ~1.60... **** that 1.75 ****... hehehe Oh well... Peace
dam_teg
Sep 25, 2009 12:37 PM
wrx-killer-Sti-eater
Nov 26, 2007 12:59 AM
lukehowell88
Oct 1, 2007 12:20 PM
killer1320
Sep 11, 2006 02:15 PM
Jockdeeznutz
10
Mar 12, 2004 09:59 AM
