how to get the shift linkage off the tranny???
easy, you pound out the little pin that holds it on there. AKA the bitch pin... Is tranny out of the car? That would make things 10 times easier.... Just unblot everything from the shifter and then pull it out with the tranny and then pound it out, if not, have fun pounding that out.
Good Luck
Blaze
Good Luck
Blaze
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">use a exhaust bolt...
bc i dont know by head the size of the punch u gotta use for it....</TD></TR></TABLE>
yep works perfectly
yep works perfectly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboZChatch »</TD></TR><TR><TD CLASS="quote">It's supposedly an 8mm punch to get it out.</TD></TR></TABLE>
yes that is correct. dont think that a tapered punch or slightly smaller punch will work, because this "shortcut" is really the long way and its what gets people into trouble in the first place. the reason is it actually makes the pin bigger since the smaller punch is being wedged into it, thus making it tighter and tighter in the hole. i'm sure an exhuast bolt would work as mentioned above; just make sure its big enough (wide enough).
The Flying Dutchmen
Nov 14, 2006 12:34 PM
mstewar
Mar 3, 2006 12:23 PM
