Somethings broke....please help
I was being an idiot doing reverse donuts and i threw it into first gear and when i went to go forward it wouldnt move. Now I hear this wierd noise comming from my drivers side tire area. I can put it into every gear without pushing in the clutch and it makes some wierd noise. Kinda like a grinding but not like grinding a gear. It gets louder as i shift gears. I have a b16a in my crx if that makes a difference.
Does anybody know what could be wrong.
Thanks for the help and yes I know i am an idiot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane »</TD></TR><TR><TD CLASS="quote">I have seen all the splines rip off the axle....
but Iwould guess that your tranny is toast..
One of the times I replaced my axles, i did not put one of them in the tranny all the way. Well as soon as I put down some power it stripped the splines off the axle. I could put it in gear without using the clutch. So what i would do is pull the axles and check the splines
thats what i was thinking to. A lot of people have been telling me different things. like it might be the cv joints the axles or the tranny. But i have been told it is really hard to blow up a tranny from doing what i was doing.
Pull it apart and find out... maybe it's something simple, like an axle. I just hope you didn't screw up the tranny, for the sake of your bank account.
reasons i am thinking its not the tranny is
None of the gears work but the axle is still spinning and making a really loud noise near the tire. If it was the tranny it would have probably made a really nasty noise when it happened. My mechanic friend just took a look at it and said the torque from going from reverse to drive really fast probably grinded the splines off the axle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaDriver85 »</TD></TR><TR><TD CLASS="quote">Yea i learned my lesson. Never doing donuts again</TD></TR></TABLE>
HAhahhaha, damn those donuts, somtimes they are too hard to resist.
Let us know what you find out....
Well i found out i destroyed my cv joint. I broke that piece with the ball bearings in it in half. My friends dad who is a mechanic told me i will have to replace the whole axle because the cv joint piece comes on the new axle. is that true?
Modified by HondaDriver85 at 8:06 PM 4/18/2003
Si Shane
Jul 23, 2007 08:29 AM
JaydMiKeY
Jul 3, 2005 02:39 PM
