Options other than FI to make a GSR faster
Old Jun 25, 2001 | 09:35 PM
GSRBUD's Avatar
New User
Default Options other than FI to make a GSR faster
What are the other options ( for the same amount of money!!!) to make a stock GSR faster than dropping a turbo or a super charger? Or Forced induction is the best bang for the buck??
Please consider the day to day driving, fun factor also!!!!
Old Jun 26, 2001 | 04:21 AM
Mike D's Avatar
Default Re: Options other than FI to make a GSR faster (GSRBUD)
get some ITR cams. Iwth some tunig you should get some decent gains. In the long run though. FI will yeild better gains for teh cash IMO. NA is expensive if you want big numbers
Old Jun 26, 2001 | 04:30 AM
joemama's Avatar
New User
Default Re: Options other than FI to make a GSR faster (hennessey)
for starters go pick yourself up an aftermarket intake, they're cheap considering how much bang for your buck you get
Old Jun 26, 2001 | 06:11 AM
eg6ajk's Avatar
Default NOS
NOS, best gains for the buck...shave off as much as 1.0+ sec of a 1/4 mile....its safe too....
its recommended by F&F crew....isn't that say anything...
Old Jun 26, 2001 | 06:24 AM
Mike D's Avatar
Default Re: NOS (eg6ajk)
all factor in what kind of driving you will be using your new found speed for. Liek drag, auto-x, road racing. Because out of those three you will only be able to use N20 for drag.
Personally N20 is the best bang for your buck no matter what anyone will say. However, liek anything else, you must tune your car so that when you squeeze your fuel will meet teh requirements and needs of N20.
I wouldnt buy unless i was into drag racing. And im not i will never have it in my car.
Spend teh cash on a new suspension and tires. that will make your just as fun to drive and you wont have to worry about melting your valves
Old Jun 26, 2001 | 09:47 AM
GSpeedR's Avatar
Default Re: NOS (hennessey)
Toda B valvetrain kit and gears = $1800
DC JDM 4-1 header = $350
JDM ITR pistons (w/ rings) = $380
Skunk2 IM = $300
Chipped ECU to 9000rpm redline (varies) ~ $160
I assume you have an intake and exhaust
So roughly $3000 and you will be fast. You must tune it though. You should be surpassing 200whp with a port and polish and bigger TB.
That's about a turbo right there. Of course $3000 will only pay for the turbo and install but not the necessary internals to up the boost. You'd have to stay around 7psi without forged pistons , crank etc.
So NA isn't that much more than FI, but you'll plateau around 200whp and is very expensive to get past that. With FI, just up the boost as long as the engine can handle it.
DC2GSR808
May 7, 2014 11:14 PM
babyphase
Jan 26, 2008 06:28 PM
Okayhoang
Jun 2, 2006 11:34 PM
gsr1997integra
Oct 26, 2001 08:56 AM
GSRBUD
Honda S2000
Jun 25, 2001 10:37 AM
