Lining up timing marks...
Old Apr 13, 2003 | 07:49 PM
Tommy_Gunns's Avatar
Default Lining up timing marks...
I installed my timing belt tonight buy could not line up the marks perfectly. I ende up about 2-3 degrees retarded from the white mark on the crank pulley. Is this normal?
Old Apr 14, 2003 | 04:31 AM
Default Re: Lining up timing marks... (Tommy_Gunns)
ttt
Old Apr 14, 2003 | 08:33 AM
red civic standard's Avatar
your timing on the cam gears is probably one tooth off.
Old Apr 14, 2003 | 06:14 PM
Tried to line up the marks again tonite. There's no way around it...either 2 degrees advanced or 2 degree retarded on the crank shaft pulley (with the cam gears lined up). If I make the gear kinda offset, then the crank shaft pulley would almost be exactly lined up.
Old Apr 14, 2003 | 06:21 PM
JPP's Avatar
JPP
Just a stupid question but did you change the head gasket for a thinner one or have the head machined ?
EDIT: Forget that...the markings would be advance a few degrees at the crankshaft, not retarded
Did you change anything before you reinstalled the timing belt ?
Modified by JPP at 10:33 PM 4/14/2003
Old Apr 14, 2003 | 08:10 PM
Default Re: Lining up timing marks... (JPP)
I didn't change anything but I'm not the original owner of the car.
Old Apr 14, 2003 | 08:14 PM
The white TDC mark is 2 degrees to the left (counter clockwise) to the timing mark on the lower cover. This is how it was before changing the belt as well.
Which position is better...crank pulley white mark 2 degrees clockwise of timing mark or crank pulley white mark 2 degrees counter clockwise of timing mark.
Old Apr 15, 2003 | 04:51 AM
TTT
civiccoupe94
Jan 11, 2008 07:08 AM
Jap_Spec_Imports
Dec 7, 2007 10:39 AM
94dxt
Oct 27, 2004 12:36 PM
brockscivic
Jul 6, 2004 10:07 AM
SC94DB8
Aug 23, 2002 09:39 AM
