99-00 si rear brakes on 92 civic hb
My first post on Honda-tech. I have posted a bit on siatlanta.com but I don't have a lot of tech to contribute, so I usually just ask questions. Here is my current question:
As the topic says, What do I need for those brakes to bolt right up. I know what booster, master cylender and porportion valve I need. But what trailing arms and e-brake cables would I use. I figure the si cables would work, and some people say the stock trailing arms would work, but I need to know for sure. I dont want any suprises. Has any one done this before? Thanks for the help.
look at the howto over at http://www.hazone.com . I used it to put 99-00 si rear discs on my 98ex.
you should probably get the e-brake cables for the 92-95si. you *could* keep your rear trailing arms if you swap over the hub/spindle/rotor/caliper assembly.
ek four
Northern California (Sales)
May 27, 2013 06:52 PM
Woogie Ctr
Dec 21, 2005 08:14 AM
