Filling SOHC tranny thru the VSS??
Old Apr 13, 2003 | 06:35 PM
eghonda's Avatar
Default Filling SOHC tranny thru the VSS??
i was reading the Axle Tutorial and i planned on refilling the tranny thru the VSS. i removed what i thought was the VSS and there was a pin like object sticking up out of the hole. the VSS is on the back left of the tranny right by the passenger side axle, correct? any help would be much appreciated as i have to drive to school tomorrow
Old Apr 13, 2003 | 06:42 PM
eh3 93's Avatar
Default Re: Filling SOHC tranny thru the VSS?? (eghonda)
the VSS is sitting about 5-6 inches to the left of the starter (closest to the firewall). Its held by 2 10mm bolts.
Old Apr 13, 2003 | 06:56 PM
eghonda's Avatar
Default Re: Filling SOHC tranny thru the VSS?? (eh3 93)
i removed both of the 10mm bolts and another close by. then i saw the pin. i pulled it out. the hole is nothing like the pic in the axle tutorial. any thoughts?
Old Apr 13, 2003 | 07:06 PM
Nameless RB26's Avatar
you only need to remove the bolt that holds it into the tranny.
One bolt. Then pull it out..
Old Apr 13, 2003 | 07:12 PM
eghonda's Avatar
Default Re: Filling SOHC tranny thru the VSS?? (Nameless EJ6)
btw, this is a D-series if it matters at all
Old Apr 13, 2003 | 07:16 PM
Bakeoff's Avatar
Why are you filling it through the VSS???? There is a fill hole on the back....
Old Apr 13, 2003 | 07:20 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Filling SOHC tranny thru the VSS?? (Bakeoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bakeoff &raquo;</TD></TR><TR><TD CLASS="quote">Why are you filling it through the VSS???? There is a fill hole on the back.... </TD></TR></TABLE>
...because it's actually easier and less messy to fill through the top of the tranny via the VSS hole.
Most DOHC (like OBD1 B16A and all Integra B-Series trannies) and SOHC VSS are identical. All you need to do is pull the ONE 10mm as mentioned earlier and then pull the enitre VSS out - gear and all.
Sounds like yours came apart upon trying to remove it. No big deal, just put it back in and take the whole thing out via the one 10mm bolt. You'll know you got it because that one 10mm bolt is really weird shaped - don't lose it!
Old Apr 13, 2003 | 07:51 PM
eghonda's Avatar
Default Re: Filling SOHC tranny thru the VSS?? (B18C5-EH2)
thanks tom. i just yanked out the whole thing and voila, instant fill hole. my car is soooo much better now without that stupid clicking.
Old Mar 28, 2005 | 09:54 PM
BLUE EH3's Avatar
Help we my pennies
vss?
Old Mar 28, 2005 | 10:00 PM
sudds's Avatar
Default Re: Filling SOHC tranny thru the VSS?? (BLUE EH3)
vehicle speed sensor damn^^^^ beat me to it
Old Mar 29, 2005 | 06:18 AM
blackeg's Avatar
Default Re: Filling SOHC tranny thru the VSS?? (Nameless RB26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless RB26 &raquo;</TD></TR><TR><TD CLASS="quote">you only need to remove the bolt that holds it into the tranny.
One bolt. Then pull it out..</TD></TR></TABLE>
this is the correct answer. this bolt is down and drivers side from the other 2 bolts. take it off, then kinda wiggle the vss and it will come out and leave you with a hole about 3/4" in diameter
Old Jul 31, 2008 | 05:53 AM
ShadowSkill's Avatar
Default Re: Filling SOHC tranny thru the VSS?? (blackeg)
Once the bolt is removed, gently pry(straight up) with a flat-head screwdriver. Sometimes the corrosion holds it in tight. Also, when filling tranny through VSS, be sure to have the ACTUAL fill whole opened on the side of the tranny, so you'll know when optimal fluid level is achieved, in other words do not over fill.
nabin
10
Jul 17, 2006 07:18 AM
dirtracer
Jan 31, 2005 06:17 AM
vmm
Jul 6, 2004 03:06 PM
mrxracing
Apr 29, 2004 03:04 PM
