jrsc bypass valve
Old Apr 13, 2003 | 05:36 PM
B_1_8_hatch's Avatar
Default jrsc bypass valve
its the black deal on the back of the intake mani for the jrsc right? if you were to blow or suck on the hose thats coming from
the bypass valve, should the little throttle body deal open up when you do so? a friend of mine is saying that it should.
Old Apr 13, 2003 | 05:54 PM
Sonny's Avatar
Default Re: jrsc bypass valve (93hb)
You would have to suck REALLLLY hard to be able to move the bypass valve at all. If you can suck that hard, you might want to consider a career in adult movies.
The bypass valve is fully open at idle (around 20" of vacuum). Most people can generate maybe 3" or so of vacuum by sucking on a vacuum line.
Sonny
Old Apr 13, 2003 | 05:57 PM
JT's Avatar
JT
If the bypass valve is working correctly, applying vacuum on the hose will cause the actuator rod to move inside the bypass valve. However, I don't think you can generate enough vacuum by sucking on the hose. Just watch it move when the engine starts.
Old Apr 14, 2003 | 10:49 AM
Default Re: jrsc bypass valve (JT)
at idle, where should the vacum guage read about?
Old Apr 14, 2003 | 11:28 AM
FMXer's Avatar
mine reads 22in-25in
D16Y8
Does anyone know how to KEEP the valve open, so that i dont go into boost while at full throttal?
Old Apr 14, 2003 | 12:12 PM
Sonny's Avatar
Default Re: jrsc bypass valve (FMXer)
You can use a zip-tie to lock the bypass valve open. That's an emissions trick.
Sonny
Old Apr 14, 2003 | 02:10 PM
JT's Avatar
JT
Default Re: jrsc bypass valve (Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">You can use a zip-tie to lock the bypass valve open. That's an emissions trick.
Sonny
It also works good if you let someone borrow your car.
DuhQbnSiLo
Jun 26, 2009 08:34 PM
vtec.dc2
Oct 15, 2006 10:19 AM
JforJonathan
Feb 5, 2003 08:30 PM
