MPFI swap question!?!
Old Apr 13, 2003 | 04:56 PM
93eg-EKhybrid's Avatar
Default MPFI swap question!?!
OK guys, I know we see these threads all of the time but this is a different question than I always see.
I have all of the parts for an MPFI swap except for the fact that I have 92-95 eg civic injectors and not the 88-91 injectors. If I were to sue the injector resistor box from the EG would it work, or do I HAVE to get the 4g injectors?? Plus, since the IM and all sensors are from an OBD1 car, will they plug into my existing wiring harness?? Thanks guys!
Old Apr 13, 2003 | 06:02 PM
Default Re: MPFI swap question!?! (93H22HB)
ttt
Old Apr 13, 2003 | 06:04 PM
Stupid Ass's Avatar
Hey man, Karma is a bitch... and you just got BITCH SLAPPED!
What goes around comes around man
Old Apr 13, 2003 | 06:10 PM
slowman's Avatar
I took way too long
Default Re: MPFI swap question!?! (SOHC NoTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC NoTEC &raquo;</TD></TR><TR><TD CLASS="quote">Hey man, Karma is a bitch... and you just got BITCH SLAPPED!
What goes around comes around man</TD></TR></TABLE>
w3rd.
Old Apr 13, 2003 | 08:41 PM
uneek4dr's Avatar
well since i dunno what that karma thing is about ill tell you. all the injectors are the same, you can use any resistor box and no harness is plug and play unless you swap out the entire SI harness and even then i dont think it will just plug and play. But to answer your question everything should work just like normal
Old Apr 13, 2003 | 08:47 PM
FourthGenHatch's Avatar
Default Re: (uneek4dr)
Weren't 92-95 Civics ODB-1? Meaning no resistor boxes?
Old Apr 13, 2003 | 09:03 PM
uneek4dr's Avatar
Default Re: (FourthGenHatch)
i was told the 92-95 EX uses a resistor box but i cant be 100% sure on that cuz i dont remember hahaha. but i am pretty sure it doesnt matter what the injectors come from and you can use any resistor box.
I have a ?? too
Someone told me when they say "you can use unused pins at b2 and b11" that even though they have a wire comming from those spots that you can just clip those wires and move them to b10 and b12 BUT if they are "unused" then why do they have wires comming from them instead of none like some of the other pin locations? am i better off just takin some from a junkyard plug and not risking cuttin my wires?
Old Apr 13, 2003 | 09:19 PM
Well my car has spots in the fuse box for things the car never came with. I figure the car is pre-wired for everything, so those wires are probably for something non of us have or something.
Old Apr 13, 2003 | 09:28 PM
uneek4dr's Avatar
but my ECU is an LX harness so i may have something they are used for thats why im asking before i cut them and find out something doesnt work later hahaha
Old Apr 14, 2003 | 05:11 PM
uneek4dr's Avatar
Does anyone know about the LX harness? i have a wire at b2 and b9 should i cut them or just get new ones? i was thinking about just rippin some from a junkyard ecu and being safe
Old Apr 14, 2003 | 05:18 PM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uneek4dr &raquo;</TD></TR><TR><TD CLASS="quote">well since i dunno what that karma thing is about ill tell you. all the injectors are the same, you can use any resistor box and no harness is plug and play unless you swap out the entire SI harness and even then i dont think it will just plug and play. But to answer your question everything should work just like normal</TD></TR></TABLE>
sorry bro but u dont know what u acutally saying....
i have done that and got the answetrs..... lets clear the questions....
if u got 5G civic injector plugs.... u need to modify OBDO injectors in order to make them fit into the plugs(i know thats what i have)
about injectors..... u cant use the 5G civic ones... they are 10-13ohms... OBDO are 1.5-3.5 ohms.... i used OBDI injectors and fried them in a matter of a month... car ran like ****.... u gotta use the OBDO.. even if u take inj resistor off they will fry... diff its on saturated and peak and hold in the way the inj internals react with the current...
and not all injectors are the same... 88-91 are 1.5-3.5 ohms, 240cc....92-00 are 10-13 ohms, and i beleive are peak and hold....(always comfuse them)and they are also 240cc. all honda injectors but the Prelude vtec ones are 240cc.. poreludes are 270cc
Old Apr 14, 2003 | 05:31 PM
4drEF's Avatar
Keyboard Humorist
<A HREF="http://honda.hybrids.jp/forum/showthreaded.php?Cat=&Board=Tech&Number=109958&pag e=0&view=collapsed&sb=5&o=7&part=
" TARGET="_blank">http://honda.hybrids.jp/forum/...rt=
</A>
Old Apr 14, 2003 | 05:39 PM
uneek4dr's Avatar
my bad that was info that was passed onto me. sorry bout that
Old Apr 14, 2003 | 05:41 PM
uneek4dr's Avatar
according to that link i was right :-)
garageEF
Mar 6, 2007 03:30 AM
Corporation
Jun 14, 2005 12:08 AM
JDMKid71
Jun 1, 2005 10:39 PM
B18c1turboedEK
Dec 5, 2003 11:59 AM
93eg-EKhybrid
Apr 13, 2003 06:03 PM
