Sohc Vtec swap in EF?
Old Apr 13, 2003 | 04:42 PM
MixdCrix's Avatar
Default Sohc Vtec swap in EF?
I need advice on the swap from people who have done it. I have a d16z6. Should I use the a6 tranny/and flywheel or am I going to use the z6 flywheel. I was also swapping in 88 teg components to raise the comp....r the pistons the same size-ne advice on this subject would help-Im going high comp sohc vtec and need to throw it in asap and i want it done right the 1st time-Send me how u did ur swap-what u used and any times? Thanks
Old Apr 13, 2003 | 04:51 PM
USDM 4G VTEC's Avatar
Default Re: Sohc Vtec swap in EF? (juicnslo)
check my signature for reference
also u dont wanna put such a high comp on the SOHC.. remember u get VTEC and that the valves go lower on vtec... u dont wanna hit them.... and yes use the Z6 flywheel , and the A6 (Si) tranny.... the best.. i am actually rebuilding one.....
Old Apr 13, 2003 | 11:33 PM
MixdCrix's Avatar
Default Re: Sohc Vtec swap in EF? (USDM 4G VTEC)
Should I use the a6 throwout bearing or z6-I thought swapping 88-89teg or a6 pistons was an easy HP gain with some block and head work....some1 give me a full slap in the face answer so I can get my swap completely donengoin
NE 1 w/this swap lmk what u did and how it worked
Old Apr 14, 2003 | 06:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juicnslo &raquo;</TD></TR><TR><TD CLASS="quote">Should I use the a6 throwout bearing or z6-: </TD></TR></TABLE>Z6 trowout bearing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juicnslo &raquo;</TD></TR><TR><TD CLASS="quote">some1 give me a full slap in the face answer so I can get my swap </TD></TR></TABLE>
WTF u waiting damn it LOL go start ur swap. ur questions are that technical and seems u got everything pretty much sorted out
TexasChaos
Apr 17, 2010 09:10 AM
the king.
Jan 28, 2007 01:55 PM
screen_name
Feb 1, 2006 07:59 AM
honcrx91si
Jul 1, 2005 12:19 AM
mattduskater
10
Sep 22, 2003 10:04 AM
