how to clean inside of engine?
Old Jun 25, 2001 | 05:24 PM
TurboMiata's Avatar
Default how to clean inside of engine?
Ok, so say you *accidentally* think you *might* have gotten a bit of aluminum shavings in the head of your engine while the cam cover was off. Some *might* have gotten into the intake side of the head as well which the intake runners and throttle body were off. What is the BEST way to go about it? We aren't talking alot here, at most a pinch. (think of a pile of it, then putting two fingers into the pile and grabbing a pinch)
Serious help is needed, is this something to worry about?
And yes, I know I deserve a
Old Jun 25, 2001 | 06:49 PM
Jared's Avatar
Default Re: how to clean inside of engine? (TurboMiata)
Are you saying cleaning it without taking the engine apart? I would suggest a shop vac with a good attachment, carb cleaner, an old toothbrush, and an oil system flush.
good luck,
Jared
Old Jun 26, 2001 | 04:01 PM
TurboInteg95's Avatar
I wouldnt really worry about it. Aluminum is pretty soft and will most likely just blow out the exhaust. Think about it, a piece of aluminum shaving rubbing agianst a steel wall wont do much. I would try to get as much out as you can but dont go crazy over it.
Old Jun 27, 2001 | 01:08 AM
TurboMiata's Avatar
Default Re: how to clean inside of engine? (TurboInteg95)
Well, I've decided I'm going to put in some oil, and do a motor flush when I finally get the engine back in the car. Hopefully, this will be all it needs. If not.........damn......I'm going to have to start walking.
slazman999
Feb 9, 2010 04:04 PM
civtic
Jan 17, 2005 09:23 AM
Red_EM1
May 30, 2004 08:41 AM
HGZ
Apr 10, 2003 03:25 PM
brega3
Mar 3, 2003 01:28 PM
