Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
motorcycle battery for race car?
Old Apr 13, 2003 | 01:28 PM
essex's Avatar
Default motorcycle battery for race car?
Can I use a motorcycle battery to run my race car?
I just need to have some sort of light weight battery in there...I don't mind giving it a boost if thats what it takes.
When I look at the battery specs what do I need to look for?
as in amp hrs? or cca
Will this battery do the job?
Honda - CBR929RR, 2000-2001
Battery Family: YTZ Factory Activated, Maintenance Free
Battery Type: YTZ10S
Voltage: 12
Capacity: 8.6
Dimensions: 6" x 3 7/16" x 3 11/16"
Weight: 7.0 lbs.
Metric Dimensions: 150mm x 87mm x 93mm
Metric Weight: 3.2 kg
Polarity:
Acid Volume: N/A
Amps: 0.9
C.C.A.: 190
Old Apr 13, 2003 | 02:22 PM
racerman50's Avatar
Default Re: motorcycle battery for race car? (essex)
Go get yourself an OEM or Westco battery for a 90-97 Mazda Miata. There is no lighter car battery made and it will last .The m/c batt or lawn tractor (!) won't last
wildman
Old Apr 13, 2003 | 02:36 PM
Geezer's Avatar
Don't know about Canada's sanctioning bodies, but many classes here in the US of A require the stock battery or one of the same size & weight.
Old Apr 13, 2003 | 03:06 PM
siisgood00's Avatar
New User
Default Re: motorcycle battery for race car? (racerman50)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerman50 &raquo;</TD></TR><TR><TD CLASS="quote">Go get yourself an OEM or Westco battery for a 90-97 Mazda Miata. </TD></TR></TABLE>
Can anyone back this up??
Old Apr 13, 2003 | 04:56 PM
preparedcivic's Avatar
Default Re: motorcycle battery for race car? (siisgood00)
I've had no problem using garden tractor batteries in my Civic. They last at least a season, sometimes two or three, depending on if I remember to take it out of the box and keep it in the basement, instead of letting it go dead and freezing solid in the garage.
Best of all is the price: 19.99 at Costco or Wally World.
Old Apr 13, 2003 | 05:31 PM
essex's Avatar
Default Re: motorcycle battery for race car? (preparedcivic)
So some of these batteries(like the one I posted above) have different amp ratings...does this matter or is the only important thing is that they are 12v ?
I found specs on the westco battery for the miata but it says it is 25lbs!! thats way too much.
Old Apr 13, 2003 | 06:14 PM
.RJ's Avatar
.RJ
25lbs is probably half the weight of the stock battery.
Pegasus auto also sells a lightweight (14 lbs?) battery that looks identical to the T1-Racing battery sold by IPS and R&D.
RJ
Old Apr 13, 2003 | 08:04 PM
hooter's Avatar
having used to own a Miata with a Westco battery, I can tell that they definitely are not light. Basically just like a stock battery but sealed since the Miata has the battery in the trunk stock.
I use a garden tractor battery in my 240sx. Seems to work fine. Its a Champion NASCAR edition battery if that matters.
-Charlie
BlackThorN
Audio / Security / Video
15
Jun 27, 2004 01:31 PM
Demonlude
Jun 18, 2004 08:34 AM
redciv
Aug 20, 2002 09:37 AM
Speedyturtle
Jun 16, 2002 07:12 PM
mafay2
Dec 5, 2001 11:23 AM
