Need help starting car
Old Apr 13, 2003 | 11:28 AM
Lonny's Avatar
Default Need help starting car
Plese help!! Last night while driving home engine stopped running. Today have checked timing belt its perfect timing marks line up perfect. Has good spark. Checked fuel flow plenty at filter and in return lines. Know matter how many time I crank engine spark plugs are still dry. I am thinking pressure regulator. How do I check the regulator??
1991 honda civic Si
No modifactions an d with full tank of gas
Old Apr 13, 2003 | 01:12 PM
jc836's Avatar
Default Re: Need help starting car (Lonny)
You say you have fuel at the filter outlet so could it be that the injectors are either clogged or have a signal problem. Check the ECU for a code before checking fuel pressure. Then check actual fuel pressure on the outlet of the filter.
I would also pull the distributor cap and make sure that the rotor is properly indexed and the screw is tight. Having spark at the wrong time will also cause the engine to stop running.
Dgib1972
Apr 23, 2018 03:15 PM
capm.stabahoe
Dec 27, 2008 06:17 PM
RadRonny
Dec 15, 2004 12:34 PM
civicspeed77
May 27, 2003 12:13 PM
lbjoe
May 22, 2003 04:41 PM
