Civic will not start.
1999 Civic Ex 1.6l replaced dist, wires, plugs, fuel pump, main relay, fuel filter, timing belt , crank sensor water pump. Car still has crank no start. Any suggestions?
Re: Civic will not start.
Do you have gas on the spark pligs? Need to make sure its getting to the cylinders. If your getting gas and spark your next place to look is to make sure your timing marks are lined up
Test for fuel flow at the return line, or use a pressure gauge. Opening the line at the filter doesn't prove how much pressure you have. It may be only a few psi, and the engine will not run on that.
+1 on check the cam timing. Then with the engine at TDC1, remove the distributor cap and confirm the rotor points at wire #1. Rotor can come loose from the shaft or distributor can be installed 180 degrees out of time.
00civicPOS
13
08-28-2014 04:48 AM
bouncing87souls
12-22-2010 09:04 PM
plantmylotus
10
10-14-2008 10:49 AM
