Cleaning SS headers. I've found something that works!
Old Jun 25, 2001 | 03:57 PM
BABY NSX's Avatar
Default Cleaning SS headers. I've found something that works!
Hey guys I just wanted to let you in on something that worked for me.
Some may recall that I installed a Spoon header a couple weeks ago. A week went by and 3 of the 4 primaries had turned a very dark purple while the last primary was a nice golden colour with a hint of purple. This had me concerned so I turned to you guys for some help. Although the resulting string did shed some interesting points as it turns out my initial concerns had nothing to do with the engines performance.
So this is what I did.
After living with the header for a week and watching it get uglier and uglier I decided I would try and do something about it. With some help from you guys I decided I would try a metal polish and see what would happen. Although it was discussed that Mothers metal polish might work I opted for a different product. Mothers’ may work but I can’t confirm that it does. My concern with any product used on a header is what it leaves behind might tarnish the header further.
I used a product called AUTOSOL, it can be found at Canadian Tire in Canada but not sure where in the US. Each tube costs about 8 bucks and I used about 1/3 of a tube. It claims to remove heat discoloration from Stainless Steele as well as leave a protective barrier that resists tarnishing.
After spending about 2 hours getting it perfect the header looked brand new. Only a slight yellowing remained… But how would it hold up?
One week has passed by and some fairly hard driving has taken place, I’m still getting acquainted with the header The header has turned a brilliant bronze colour with only the slightest hint of purple. The colour has pretty much stabilized over the last few days. Most importantly for me is the fact that all 4 primaries are now the same colour.
Biased on this result I wouldn’t hesitate recommending everyone spend some time polishing his or her headers prior to installation. I believe what I experienced initially was a result of residues that were left on the metal.
I’m going to be going to the track later this week, which should really test things. I’ll let you know how it turns out. I will try to get some pictures of the results soon!
Hope this helps!
Regards,
Old Jun 25, 2001 | 07:47 PM
SamB's Avatar
New User
Default Re: Cleaning SS headers. I've found something that works! (BABY NSX)
Cool
So the original problem was that the SS had turned purple, and then after cleaning it went bronze??????
Sam
Old Jun 25, 2001 | 08:15 PM
DC2#309's Avatar
New User
that indicate that 3 of your 4 primaries are leaner than the rest. Leaner runs hotter.
Old Jun 25, 2001 | 09:43 PM
Big Phat R's Avatar
Hey WENOL works good too.
Old Jun 25, 2001 | 10:07 PM
ALF's Avatar
ALF
Thanks for the info! I knew the stains could be removed, but I could never get an exact product name from anyone.
Old Jun 26, 2001 | 04:08 AM
Boba-Fett's Avatar
New User
Default Re: Cleaning SS headers. I've found something that works! (Big Phat R)
Wenol is an awesome product. I used it one time to polish my Intake Manifold on my old 93 T/A.
Boba- who misses his T/A.
Old Jun 26, 2001 | 04:32 AM
BABY NSX's Avatar
Default Re: Cleaning SS headers. I've found something that works! (DC2#309)
Actually no, I checked the plugs and they were all identical, checked compression and they where all within +/-3psi. Engine pulls strong so I believe things are well matched.
My only conclusion can be that 3 of the 4 primaries had some form of residue on them that resulted in them tarnishing much quicker then the 4th. We are not talking a light purple here but a very, very dark purple. I personally think that a slight colour change is fine but what I had would have been unacceptable to anyone.
The most important point to make about this whole thing is that there is stuff out there that works. If you feel your header may have similar problems to mine or you simply want to spruce it up then you now know you have a solution.
Regards,
Old Jun 26, 2001 | 04:35 AM
Back in Black's Avatar
Rather OG
Boba/Big Phat-
Where does a fellow owner purchase WENOL? Thanks!
Old Jun 26, 2001 | 04:48 AM
Boba-Fett's Avatar
New User
Default Re: Cleaning SS headers. I've found something that works! (TypeRJason)
Jason,
The last time I purchased Wenol it was from Pep-Boys. I also purchased some from the Super Chevy show last year.
Boba- who still likes domestics with big V8's
Old Jun 26, 2001 | 04:50 AM
Rather OG
Default Re: Cleaning SS headers. I've found something that works! (Boba-Fett)
Thanks bounty hunter, I appreciate it. On the V8 note, did you see the FATF yet? How 'bout that last scene? Mmmm good!
Old Jun 26, 2001 | 04:51 AM
Boba-Fett's Avatar
New User
NO problem, Havent seen it yet. I was going to leave work early one day to watch it and be faraway from the Rice clowns.
Boba- who will probably leave early on Weds to go see the F&F.
Old Jun 26, 2001 | 04:55 AM
sgT's Avatar
sgT
wow, good thing you were able to clean that header or else it might not
perform as well.
Old Jun 26, 2001 | 04:56 AM
Rather OG
You will LOVE the finale! The Supra and a classic V8 monster called the...
You didn't think I was going to ruin it for ya, did ya? Hehe
Old Jun 26, 2001 | 05:54 AM
Tbone's Avatar
The discoloration on s.s headers is caused the oils in your hands when you touch it. Always wear rubber gloves when installing one or at least wipe it down with some rubbing alchol before you start it for the 1st time. I work with stainless jet engine housings at work and we have to burn them out at 650 deg when we get them( we apply thermal barier ccoatings) and wherever the part is touched with bare hands will turn purple/blue.
Old Jun 26, 2001 | 05:56 AM
BABY NSX's Avatar
Default Re: Cleaning SS headers. I've found something that works! (sgT)
perform as well.
So I wan't my $1000 header to look nice! Is that a problem? you know I wash my car too! No I won't polish my header every week, or every month, but once a year maybe.
Just trying to help that's all!
Regards,
Old Jun 26, 2001 | 06:02 PM
DC2#309's Avatar
New User
normally to find out which cylinder is richer or leaner by taking out the head and look at the valves. normally on the first cylinder you will find it is the leaner, second one will be richer and so on.
Old Jun 26, 2001 | 06:06 PM
Big Phat R's Avatar
Regards,
Mine turned purple from oil vapour when I pulled out the dipstick. If it's on the #4 primary I suspect it's the oil from someones hands.
WENOL (red tube) is everywhere. Walmart etc. You can find it in the area of the store where they sell household polishes and such.
Old Jun 26, 2001 | 06:35 PM
Mike K's Avatar
Installed a Mugen 2.5" collector header on my friend's 00 Civic. Turned bronze color within minutes of running. After three weeks, still looks the same bronze. No purple, blue, green, etc.
A/F ratio is 13.1:1 constant from 3500 to 8500, with a slight jump to 13.9-14.0:1 at VTEC transition. Runs super good.
fitseries3
Feb 8, 2013 07:02 AM
joeyjoeysee
Feb 18, 2007 07:09 PM
fauxhawkid
Jan 12, 2006 04:04 PM
Ninja Mike
Jul 18, 2004 05:55 PM
Jason
Nov 5, 2001 05:00 PM
