A/C system 90% out today... (insert pic of me flipping off my CRX)
Old Apr 12, 2003 | 07:39 PM
Mr.Saturn's Avatar
Default A/C system 90% out today... (insert pic of me flipping off my CRX)
Not really much to say, I just took the A/C system out of my CRX today. Everything but the compressor is now out. It all went just as I thought it would, with some cursing and pain thrown into the mix as well.
The biggest problem I found was the damn condenser in the front would not fit between the radiator and the frame. I didn't wanna force the radiator too much because I thought it was flexing. When I finally realized the mushy feel was just the radiator hose and not the radiator itself the condenser came right out (over a 20 minute period of time).
If anyone has any questions feel free to ask while its still fresh in my mind.
Old Apr 12, 2003 | 07:46 PM
keebler65's Avatar
Default Re: A/C system 90% out today... (Mr.Saturn)
sounds good. you'll love how much cooler your car will run
Old Apr 12, 2003 | 07:53 PM
FourthGenHatch's Avatar
Default Re: A/C system 90% out today... (keebler65)
To get the condensor out I just unbolted the radiator brackets and tilted back the radiator and pull the condensor right out.
Old Apr 12, 2003 | 08:20 PM
Mr.Saturn's Avatar
Default Re: A/C system 90% out today... (FourthGenHatch)
Ditto, it just freaked me when I tilted the radiator and it felt mushy, thought I was bending a bracket or something.
Old Apr 13, 2003 | 06:23 PM
Mr.Saturn's Avatar
Drove car today... something smelled sweet, the got overpowering, then steam pours out the sides of the hood, for a million bucks can neone guess what happened???
Answer: The top of the radiator blew around the engine side seal and poured coolant all over the heat shield and fan (and in turn splattered everywhere). Fun fun.
How much is a new radiator? I'm gonna find out tomorrow neways, just venting, but yah if just rocking the radiator back did that... I doubt it had much life left neways.
Old Apr 13, 2003 | 06:53 PM
Yeah I had a leak in one of my Coolant hoses which sprayed coolant from one side of the engine onto the intake manifold creating white smoke. Took me forever to figure out what was going on.
Old Apr 13, 2003 | 06:57 PM
MrTodd's Avatar
Beside the fact that your radiator is dead... (BTW: I heard Integra radiators will fit our 4g cars... Can't remember which year though! )
Did you notice any increase in power, due to the weight reduction w/out A/C?
Old Apr 13, 2003 | 11:23 PM
Mr.Saturn's Avatar
Default Re: A/C system 90% out today... (MrTodd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrTodd &raquo;</TD></TR><TR><TD CLASS="quote">Beside the fact that your radiator is dead... (BTW: I heard Integra radiators will fit our 4g cars... Can't remember which year though! )
Did you notice any increase in power, due to the weight reduction w/out A/C?</TD></TR></TABLE>
hahaha I didn't take it over 3 grand cuz I didn't wanna overheat the engine on my way to work. Engine sounds louder cuz of the empty space under the dash now though
Old Apr 14, 2003 | 08:07 AM
unltdacc12's Avatar
How much of a pita was it to take out the under dash stuff??.. I removed everything under the hood, all i have left is the under dash stuff
Old Apr 14, 2003 | 08:46 PM
Mr.Saturn's Avatar
Default Re: A/C system 90% out today... (unltdacc12)
Under dash part I had fun with actually, it was really easy as long as you have the Non A/C tube to replace the A/C evaporator. The only tough part was disconnecting the lines under the hood to under the dash, huge *** ~20mm bolt and not much room with the PCV on one side and a wiring harness on the other.
Old Apr 15, 2003 | 12:29 AM
Mr.Saturn's Avatar
100% out now, compressor was one of the easiest parts... wire harness however I won't comment on
Old Apr 15, 2003 | 05:34 AM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
It's sure as hell not the 86-89, That's what I have in my car and it just sits there, Nothing holding it in.
Old Apr 15, 2003 | 09:01 PM
Mr.Saturn's Avatar
Default Re: A/C system 90% out today... (h8tred)
Got my new radiator with a lifetime warrenty, all nice a greased up and shiny its goin in tomorrow, any recommendations on what to fill it with, I know the usual 50/50 mix but whats up with this water wetter stuff? Do you not use antifreeze with water wetter?
Old Apr 15, 2003 | 09:48 PM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Saturn &raquo;</TD></TR><TR><TD CLASS="quote">Got my new radiator with a lifetime warrenty, all nice a greased up and shiny its goin in tomorrow, any recommendations on what to fill it with, I know the usual 50/50 mix but whats up with this water wetter stuff? Do you not use antifreeze with water wetter?</TD></TR></TABLE>
Good to hear that it will be back on the road soon So what radiator did you end up going with?? I started ripping apart my rex to find out that the radiator is pretty corroded so I figured that I would get a new one while its all apart.
Old Apr 15, 2003 | 11:14 PM
Mr.Saturn's Avatar
Default Re: A/C system 90% out today... (Vinceg99)
the 100 dollar stock replacement for now anyone at all know about the water wetter or similar stuff?
Old Apr 16, 2003 | 05:52 AM
Doodoo's Avatar
I used it recently. I didn't notice a difference because my headgasket was blown.
I will be using it again though when I get a radiator flush, along with 50/50.
Old Apr 16, 2003 | 04:16 PM
Mr.Saturn's Avatar
Default Re: A/C system 90% out today... (Doodoo)
Radiator is in and all nice engine runs smoother it seems, and idle isn't bumpy anymore, may have had something to do with the A/C belt, I really don't know how it could have been the old coolant/radiator, most of the coolant came out clean as new. Still need to get a new alternator belt to fix the squeaking under acceleration but at least I can reach the belt now.
Old Apr 16, 2003 | 10:19 PM
G2turbo_terror's Avatar
so did you get the system drained first? How does that work with taking all that out and having a full system?
Old Apr 17, 2003 | 12:12 AM
Mr.Saturn's Avatar
Default Re: A/C system 90% out today... (G2turbo_terror)
Call around, about 1 in 3 shops will discharge the A/C system for free, they can resell the refrigerant.
office888
16
Dec 5, 2006 05:10 PM
MikesArmy
Mar 7, 2006 08:16 PM
FF-Greg
Jan 25, 2006 06:52 PM
LostCRX
Feb 22, 2004 11:33 AM
