Quick Header Question???
Old Apr 12, 2003 | 06:54 PM
93EH6
Guest
Posts: n/a
Default Quick Header Question???
Now i know that the 99-00 civic si header will fit a del sol with a b16 but will it fit a del sol with a b18b???
Thanks for the help;
Old Apr 12, 2003 | 06:56 PM
boostsohfast's Avatar
Default Re: Quick Header Question??? (BLACK DEATH)
I know it will bolt up but I'm not sure if the length to the cat is the same.
Old Apr 12, 2003 | 07:01 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: Quick Header Question??? (boostsohfast)
yes it will bolt up but the cat length will have to modified and probably the flange will have to be turned
Old Apr 12, 2003 | 07:03 PM
Nine's Avatar
Back it up a sec, why do you think that will fit? The b18b is quite a bit deeper then the the b16a.. how will it fit?
Old Apr 12, 2003 | 07:07 PM
Default Re: Quick Header Question??? (Nine)
What do you mean when you say deeper? The way a header or exhaust manifold bolts up is the same on b series motors.
Old Apr 12, 2003 | 07:09 PM
93EH6
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nine &raquo;</TD></TR><TR><TD CLASS="quote">Back it up a sec, why do you think that will fit? The b18b is quite a bit deeper then the the b16a.. how will it fit? </TD></TR></TABLE>
Ok so what header do you sujest to get for that application.e
Old Apr 12, 2003 | 07:12 PM
93EH6
Guest
Posts: n/a
Default Re: Quick Header Question??? (CiRcUiTsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiRcUiTsi &raquo;</TD></TR><TR><TD CLASS="quote">yes it will bolt up but the cat length will have to modified and probably the flange will have to be turned</TD></TR></TABLE>
Wait a sec why would the flange have to be turned if the header is already meant to fit on the
del sol vtec and the 00 si
Nine's Avatar
I thought that the b18 blocks were deeper then the b16s, so that b16 headers wouldnt clear the oil pan.. am I wrong about this?
Old Apr 12, 2003 | 07:16 PM
jus f0 dekarayshunZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK DEATH &raquo;</TD></TR><TR><TD CLASS="quote">
del sol vtec and the 00 si </TD></TR></TABLE>i retract my statement...im not sure if the flange will have to be turned...i know this is true for b18c1 b18c5 and b16 headers....when they are interchanged the cat flange has to be changed...i know the header will fit on the motor im not sure about the fitment on the cat though
R.A.T.
Dec 18, 2007 08:24 AM
B serious
Mar 20, 2007 06:09 PM
watsvtecEK
Sep 11, 2005 11:01 PM
youngkow
Sep 14, 2004 02:01 PM
IntegraBoy04
Sep 11, 2003 02:56 PM
