type of oil?
Old Apr 12, 2003 | 05:34 PM
shadowstylz's Avatar
Default type of oil?
Well my car smokes real bad, when it warms up and start moving it around, the previous owner told me it burns oild like hell,and I should check it every week, so what kinda oil should I put in my car guys?
btw its a 90 civic hb dx, stock motor.
Old Apr 12, 2003 | 06:06 PM
Ef Whore's Avatar
Default Re: type of oil? (shadowstylz)
Try some Quaker State Higher Mileage.
Old Apr 12, 2003 | 06:57 PM
SteveeeO's Avatar
Default Re: type of oil? (Ef *****)
20w50 works best for me, that high milage stuff is a scam... been through it all, spending $6 for stop oil burning stuff, trying new oil filters, trying different weights/brands of oils... seems like the 20w50 burned the slowest, but still smoked very badly
just get the cheapest oil you can get, the heaviest weight, and buy a lot of it... do a swap ASAP
Old Apr 12, 2003 | 08:30 PM
the DR.'s Avatar
Default Re: type of oil? (SteveeeO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveeeO &raquo;</TD></TR><TR><TD CLASS="quote">just get the cheapest oil you can get, the heaviest weight, and buy a lot of it... do a swap ASAP</TD></TR></TABLE>
honestly, listen to that piece of info, instead of masking the problem, you should be addressing it... you can go through alot of money buying oil every week or fix the problem that's making the oil burn (or swap )
Old Apr 12, 2003 | 09:45 PM
Full-Race Henry's Avatar
I say do a swap. You could buy mine
Old Apr 12, 2003 | 09:54 PM
Rob!'s Avatar
Default Re: type of oil? (EF8_Fan)
i would work on saving for a swap...you could do something cheap to hold you over if you dnt have much money....but that problem seems like it can be costly
1990hondaHF's Avatar
nothin' like some good old 20w50 and some motor honey....that should stop the smokin'...... Really, If you are at that point it's time for a new engine!
Old Apr 12, 2003 | 11:06 PM
TRE_'s Avatar
i aggree with this guy^^ 100%. my brothers old car burned oil, so he tried all those additives and **** but NONE of it worked, so he just bought cases of the cheap oil and did that for a few months until he could save enough $$ for his swap.
Old Apr 13, 2003 | 06:01 AM
Default Re: type of oil? (glowing_rotors)
what type of swap should I do, cheapest.... I dont want a zc
Old Apr 13, 2003 | 06:10 AM
SteveeeO's Avatar
z6, it's newer, VTEC, has a good amount of power, pretty cheap ~$1400 to do it right
or you could always just get an si motor from http://www.nippon-motors.com ~$800 to do it right
powerdbygarrett
Apr 28, 2008 07:28 AM
ahron
Sep 9, 2007 06:59 PM
OldSkoolEskimo
Jan 3, 2006 12:11 PM
Vouthanack
Jul 30, 2004 11:18 AM
Jer'rome
Mar 6, 2004 11:25 AM
