what do i have to do to put my si motor/tranny in my dx
Old Apr 12, 2003 | 04:38 PM
88rexdxa6ed's Avatar
Default what do i have to do to put my si motor/tranny in my dx
i'm new to the honda thing so any help would be appreciated. my first question is do i have to use the si ecu? will the dx cv's fit the si tranny?
Old Apr 12, 2003 | 05:00 PM
Malgerus's Avatar
Default Re: what do i have to do to put my si motor/tranny in my dx (88rexdx)
First of all.. search is your friend.
But I'll help ya a bit:
You need to use the Si computer, and convert to MPFI. Here's some instructions: http://www.4thgenerationcivic.com/ho...conversion.htm
Reuse your mounts, and your DX axles will work.
Old Apr 12, 2003 | 05:59 PM
what all parts do i need off the si?
Old Apr 12, 2003 | 08:13 PM
SteveeeO's Avatar
resistor box, ecu, injectors, intake mani, and the harness
this has been discussed way too many times, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> https://honda-tech.com/zerosearch </TD></TR></TABLE> will find your answers much faster
Old Apr 12, 2003 | 09:35 PM
Red_Si's Avatar
Default Re: what do i have to do to put my si motor/tranny in my dx (SteveeeO)
exactly what they said. good luck with your project tho!
Old Apr 12, 2003 | 09:37 PM
Full-Race Henry's Avatar
i have an extra SI pm6 ecu if you need one. Let me know
Old Apr 12, 2003 | 10:41 PM
7PSI CRX's Avatar
Default Re: what do i have to do to put my si motor/tranny in my dx (EF8_Fan)
You are also going to need a Si of HF distributor.
Old Apr 13, 2003 | 03:38 PM
Default Re: what do i have to do to put my si motor/tranny in my dx (7PSI CRX)
cool, i have a whole running 91 si for parts. if anyone needs any parts except for the motor tranny and ecu let me know.
Old Apr 16, 2003 | 02:31 PM
i was told by someone onhere that the 88 dx axles won't fit the tranny. does anybody know if this is true?
Old Apr 17, 2003 | 07:43 PM
SteveeeO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88rexdx &raquo;</TD></TR><TR><TD CLASS="quote">i was told by someone onhere that the 88 dx axles won't fit the tranny. does anybody know if this is true?</TD></TR></TABLE>
no they won't fit
Old Apr 17, 2003 | 11:23 PM
i was told by like ten people opn here in my other post that they will<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveeeO &raquo;</TD></TR><TR><TD CLASS="quote">
no they won't fit</TD></TR></TABLE>
Old Apr 18, 2003 | 06:29 AM
Vinceg99's Avatar
Why would it matter if you have a whole running 91 Si?? Why wouldnt you just use the axles from it if your going to be swapping the motor and trans?? I dont know if they will fit or not?? (the 88's that is) I thought that they would but I could be wrong? I know that it will fit in the hub I just dont know about it fitting into the tranny.
keeblar
11
Jan 28, 2025 02:53 PM
lshatch1.8
24
Jan 19, 2006 09:39 PM
dingusjt
Nov 22, 2002 05:59 AM
shoebox
10
Oct 29, 2002 07:38 AM
simike
Aug 13, 2002 02:50 PM
