Need Lost INstructions ASAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Need GC assembly instructions...some please take a picture or post the instructions
Goes on GSR Integra..need to know the order of washers and bumpstops...etc...
Typically, you will need to trim about 1/3 of your bumpstops.
You will need to trim your dustboots so that only about 1 1/2" is left. If you don't, they will bottom out on the sleeve.
The really important washer is #15. Make sure the taper is set up with the larger opening down.
Which washer is left over? #15 has the tapered opening & is usually silver. #10 is flat & is usually black. #6 has an outside edge that curls up. Did you also get new shocks? Most of the time, they come with new parts #'s 6,7 & 14.
GC probably sent you a washer, when added to your stock parts, left one extra.
There's two washers per shock ... well, if you don't use the dust boots there is. There might be three on there from the factory. Ok... I'm confusing myself now.
bumpstop...then washer (above)
then dust cover...then washer
Am i correct?
and This is eme after to days of screwin **** up
jxhxb
Jul 15, 2008 04:08 AM
