brainstorming...pick an engine swap
Old Apr 12, 2003 | 09:01 AM
1990hondaHF's Avatar
Default brainstorming...pick an engine swap
OK...I've been searching for a new project car to work on and am looking into engine options: All of the below will include a turbo kit of some type...most likely a junkyard system because price is a major factor . Assume these will be going into a 1990 Civic HB SI. Thanks.
Modified by 1990hondaHF at 1:22 PM 4/12/2003
Old Apr 12, 2003 | 09:06 AM
Archidictus's Avatar
Unceasing Measure
Default Re: brainstorming...pick an engine swap (1990hondaHF)
if you're planning on turbo, the b16 will net you the best results.
Old Apr 12, 2003 | 11:58 AM
martini's Avatar
for turbo? go for the b18b. you don't need no VTEC. but you get the extra diaplacement to spool it up quicker, and you get a relatively low compression ratio. Plus, the b18 is much cheaper than the b16a.
Old Apr 12, 2003 | 11:59 AM
Kaan's Avatar
Loved
Community Favorite
Default Re: brainstorming...pick an engine swap (Archidictus)
I dont happen to agree with the B16 being the best turboed motor... get an LS motor (B18) and the tranny. You can vtec the LS motor when you have more money. You'll have more torque and displacement power then the other motors in the long run i think. The ZC will most likely be your cheapest swap though. Its got ok power but not the best aftermarket support. Its basically up to you.
Old Apr 12, 2003 | 04:21 PM
blacksheep's Avatar
The stock engine and the ZC will net better results from a junkyard turbo better than the B-series engines will. At least for the least amount of $$ invested.
Old Apr 12, 2003 | 04:27 PM
Malgerus's Avatar
Default Re: brainstorming...pick an engine swap (blacksheep)
I will pick B18B over ZC simply because it is a better engine. It may cost more to install, but it's newer, more powerful, and has way more support. Plus, a turbo B18 will kill a turbo ZC even if they run the same boost.
Old Apr 12, 2003 | 08:07 PM
SteveeeO's Avatar
Default Re: brainstorming...pick an engine swap (Mr. S)
build up the a6, then boost it
would be the cheapest route, and relatively quick
Old Apr 12, 2003 | 09:09 PM
sabertooth's Avatar
if ur lookin not to spend too much then go with a zc
Old Apr 12, 2003 | 09:20 PM
Red_Si's Avatar
Default Re: (sabertooth)
since price is a major factor my first choice would be the b18b. It will have a nice torque curve and be relatively cheap. second choice would be the d16a6 with a nice cam and some porting!!!
Old Apr 12, 2003 | 09:27 PM
Default Re: (Red_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_Si &raquo;</TD></TR><TR><TD CLASS="quote">...my first choice would be the b18b. It will have a nice torque curve and be relatively cheap...</TD></TR></TABLE>
I like the idea of having the low end torque of the b18b to offset any lag from the turbo...but I had one that spooled up too quick(i.e. t25), would traction be a problem? What about if it was a t3 or t4?
Old Apr 12, 2003 | 09:28 PM
Full-Race Henry's Avatar
I would recommend boostin the LS motor. I had a b16 turbo and it wasnt fast enough. Now im buildin a ls/vtec turbo
Old Apr 14, 2003 | 09:28 AM
BseriesHatch's Avatar
Go with the zc. The junkyard turboes are the cheapest for the zc and the zc will still put out a lot of power.
Old Apr 14, 2003 | 01:56 PM
89civic1.8T's Avatar
Default Re: brainstorming...pick an engine swap (Novtec)
D16 or ZC you can make plenty of power with them and your cars front end won't be soo heavy.
Old Apr 14, 2003 | 04:53 PM
Double_R's Avatar
I saw a CRX with an H22. That's stupid to me, he'll do nothin but peel out all day!
Old Apr 15, 2003 | 04:47 PM
Maddhatcher's Avatar
you probably already know of the site http://www.homemadeturbo.com, if not go check it out.
Forget about the T25 go with a 14b from the 1st gen eclipse. It is a bit bigger than the t25, can be had from ebay for a hell of a price, and you will get better results form it, as seen on the site.
Good Luck and pick wisely...
Old Apr 16, 2003 | 08:16 AM
Default Re: brainstorming...pick an engine swap (Maddhatcher)
As far as turbos, I think it would make sense to go with a small fast spinning one for the ZC....not much torque to begin with so turbo lag would hurt that even more...having never pieced together a turbo before this is just theory.
Old Apr 16, 2003 | 07:00 PM
88civicHB703's Avatar
recommend hybrid engine... b18 head b16 bottom.. i heard they give nice compression and since u're moding this is a nice low end build up price i would say.
Old Apr 16, 2003 | 07:07 PM
Default Re: brainstorming...pick an engine swap (88civicHB703)
lemme fix my self... b18(LS) block and b16 head.. for the hybrid... it a crazy combo but it crankz hp....
Old Apr 16, 2003 | 07:09 PM
bfrank81's Avatar
Default Re: brainstorming...pick an engine swap (martini)
Stock Si. Be different!
Old Apr 18, 2003 | 06:17 AM
Default Re: brainstorming...pick an engine swap (bfrank81)
zc and a t-25 turbo.. electronic boost controller and rebuild the engine to support is some work but it might be a cheap way to go...
Old Apr 18, 2003 | 10:07 AM
V3locity's Avatar
the people voting b16 don't read.
ls turbo is the way to go.....i promise.
Old Apr 18, 2003 | 11:01 AM
spun Vtec's Avatar
Default Re: brainstorming...pick an engine swap (illdezignzls)
is anyone saying anything about the z6!!??
i say go with a d16z6=cheap and easy
but if your going turbo
go with the b18b
dirtridernathan
Jun 29, 2013 10:13 PM
95RS - Djin
Mar 25, 2008 05:21 PM
lukedogg49525
Nov 10, 2001 04:33 PM
punk749
Nov 5, 2001 06:37 PM
