Coolant temp?????
Old Jun 25, 2001 | 07:29 AM
jmhai's Avatar
Default Coolant temp?????
I am driving along and the temp goes from normal to past the red mark it tops out instantly. I replaced the sensor with a used one from an old engine that was working when removed and still does the same thing. It is not over heating. Any suggestions ? thanks Jim...
[Modified by jmhai, 4:29 PM 6/25/2001]
Old Jun 25, 2001 | 09:04 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: Coolant temp????? (jmhai)
Is this a G4 Civic? On my old 88 Civic, the same thing happened. It went past the red mark. That is a sign of the temp gage gone bad. If your engine is not boiling over like it's overheating, then you got the same problem as I did. The dealer replaced it back then. He informed me (at that time when I called on the side of the road) that I had nothing to worry about because an overheat car will not go past the red mark. It would have boil over before that. So it was safe enough for me to drive and make an appointment later.
Old Jun 25, 2001 | 09:32 AM
jmhai's Avatar
Default Re: Coolant temp????? (GoLowDrew)
I guess I will just buy a new one and give it a try since the other one I tried was old and used BTW I have a 88 CRX Si. Thanks http://albums.photopoint.com/j/View?...051&p=44780927
Old Jun 25, 2001 | 12:15 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Pretty nice shine for a car that's over 10 years old.
mystikalflip
Jul 22, 2008 06:32 AM
DIYaccord
Jun 7, 2006 02:37 PM
Mo_HCC
Jan 26, 2006 03:17 PM
Filliam H. Muffman
12
Feb 27, 2004 11:38 AM
Fuster_Cluck
13
Dec 22, 2002 07:19 AM
