so you want to gut your hatch....... heres some info
Old Apr 11, 2003 | 09:43 PM
Urban Business
Guest
Posts: n/a
Default so you want to gut your hatch....... heres some info
here is some info on how much weight you're actually saving. i am a firm believer that weight reduction is one of the best mods you can do. when my std was stock, i was able to gain 5mph out of every gear. this is my 2nd gutted hatch. i didn't destroy it this time while gutting so if i ever wanted to "ungut" i could do so w/o using duct tape once everything was pulled out, i tried my best to weigh it on a bathroom scale. quite a challenge b/c its a shitty way of weighing odd shaped objects, however it should pose a ballpark illustration of interior component weight.
when gutting its easiest to start from the back and move to the front. everything is pieced on in layers, pull off the top layers first and work your way down. this is common sense. take your time don't brake anything in case you need it later or you want to sell it.
as some of you may know, my 88 std got hit on monday:
so on thursday i was able to pick this up:
1st mod was this:
i took pictures of the scale for as many piece as i could i believe im missing 2 pics of some random pieces of plastic or a bag of bolts or something. i should have weighed all the plastic together and all the hardware together but didn't. (bags of hardware are taped to the corresponding plastic panel, im not going to mix **** up).
here is a run down of the heaviest things in your hatch (interior wise i haven't pulled door panels yet I'll post their weight tomorrow.), heaviest 1st (from a 1990 automatic dx ):
Seats: 32lbs each
Spare tire: 23lbs
backseat, back support: 20lbs
floor mats: 8lbs (i had 8lbs of mats, you prolly wont )
front carpet w/ sound-deadening: 8lbs
rear seat cushion: 8lbs
rear seatbelts and hardware: 6lbs
list goes on: heres pics of what i weighed and their weights. if nothing showed up on the scale, i considered it to be 1lb. not accurate but sort of accounts for any margin of error. also im not pushing down on anything, im trying to balance it so i can get it weighed. obviously pushing down would increase its presumed weight and ruin the purpose of this write up.
(that board doesn't weight ****)
in all i pulled about 159lbs of weight. if you go by the 100lbs = 1 tenth rule this is .159 sec saved in the 1/4. however, i always felt that a spare tire was a tenth in a 4th gen <IMG NAME="icon" SRC="http://images.h
Old Apr 11, 2003 | 09:49 PM
SiR Kid's Avatar
New User
Default Re: so you want to gut your hatch....... heres some info (limoZeen)
Riiiight. I've always wondered. FYI, a better way to just the weight would be to weigh yourself, then pick up the object and weight both of you.
(You + object) - You = Object's weight
Should be somewhat more acurate that what you did.
Mad props for taking the time, anyway.
Old Apr 11, 2003 | 09:58 PM
Urban Business
Guest
Posts: n/a
Default Re: so you want to gut your hatch....... heres some info (SiR Kid)
yeah i thought about that however this way helps fight off the number *****. i can prove that i did get the numbers i got.
Old Apr 11, 2003 | 10:56 PM
smokey2.0's Avatar
good piece of work, this makes me wanna put my crx on a diet!
Old Apr 11, 2003 | 11:09 PM
G2turbo_terror's Avatar
Nice, I'm gonna do the same this summer.
Just wondering though, did you run into any problems removing the rear "trays"? I had a nut come un-glued or welded on the back making it impossiable to removethe bolt (Its the middle bolt) . I can cram my hand back there through the tail light access pannel but not sure if I can fit a pliers to hold the nut. Any one have any suggestions?
Old Apr 12, 2003 | 08:56 AM
Urban Business
Guest
Posts: n/a
Default Re: so you want to gut your hatch....... heres some info (G2turbo_terror)
i dont know what your talking about actually
Old Apr 12, 2003 | 09:37 AM
Okay, I'll try to describe this better. You know the 2 plastic pieces that the rear privacy cover fits inbetween? Thats what I'm talking about. Theres either speakers or a shallow useless rectangle to keep junk in. Theres 3 bolts holding 'em inplace, the nut of the middle bolt is spinning w/the bolt. The nut is located in the body and I can cram my hand up there through the tail light access panel but its difficult to get pliers up there to hold the nut. Seeing as you've stripped 2 interiors have you run into this problem or know of a solution that doesn't wreck the plastic?
I'm tempted to cut the head of the bolt off and deal w/it when ALL the trim is out of my way.
Old Apr 12, 2003 | 09:56 AM
Hcivic88's Avatar
Default Re: (G2turbo_terror)
G2turbo_terror - I know what bolt you're talking about, and I know what your having trouble with. Although I've stripped a couple cars before too and have never ran into this problem before. like you said, id probably just grind the head of the bolt off.
Old Apr 12, 2003 | 10:03 AM
Louie B.'s Avatar
my std didn't even come with those trays...
I've been wrestling with the weight issue in my hatch... I'm going to start autocrossing it on the 19th (I'm already pre-registered for the next 8 races) but it's also my daily driver and I like my creature comforts, I've added a ton of dynamat to the doors, power windows, a subwoofer enclosure that's fiberglassed into the spare tire well so it's not removeable, among other things. All in all It's weighing in at 2500lbs with me in it (me=280lbs). not good!
I'm thinking I'd be better off getting a second hatch for racing than to try to strip it on race day and load it back down again for daily driving.
Old Apr 12, 2003 | 10:19 AM
Ben Ogle's Avatar
Default Re: (thumpu77)
Heres some:
http://www.geocities.com/ben_ogle/efdaweight.html
it'll never be done.
Ben
Old Apr 12, 2003 | 10:22 AM
Ben Ogle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumpu77 &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking I'd be better off getting a second hatch for racing than to try to strip it on race day and load it back down again for daily driving.</TD></TR></TABLE>
Stripping your car will put you in a mod class. not good. Leave the interior in.
Ben
Old Apr 12, 2003 | 11:24 AM
JaiDM's Avatar
Default Re: (Ben Ogle)
your cool!
Old Apr 12, 2003 | 12:03 PM
martini's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limoZeen &raquo;</TD></TR><TR><TD CLASS="quote"> when my std was stock, i was able to gain 5mph out of every gear.[/i]</TD></TR></TABLE>
just wanted to point out that the only way you are going to gain MPH out of a gear, is to change the gearing in the tranny (or get bigger tires/wheels)
Old Apr 12, 2003 | 01:54 PM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: so you want to gut your hatch....... heres some info (martini)
I don't know about all that, With my sub and rear seats in, I never made it past 115 on the highway. I took the sub, amp, Rear seats, And front passenger seat out, I was able to bury the speedo (Best guess is 125 max)... Mind you this took a long time and many many miles of w.o.t.. Does that mean I changed my gearing or wheel size? Nope... I know alot of people are gonna say bullshit, But they can kiss my ***, I have better things to do than be a stunna yo. oh, And I only did it twice, The second time my o2 crapped on me and the car died on the side of the road. Oh well, Whatever. Nice write up man, Thanks for taking the time and energy to help us fellow 4g lovers out.
Old Apr 12, 2003 | 03:25 PM
goforbroke's Avatar
MEAT PATTY
Default Re: so you want to gut your hatch....... heres some info (h8tred)
Yeah being in S mod sucks specially when your on 13 inch skinnies with no suspension work done. I'm just started autox as well and I'm learning the hard way but that is all going to change very soon after I get the suspension and Azenis.
Old Apr 12, 2003 | 05:43 PM
Urban Business
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by martini &raquo;</TD></TR><TR><TD CLASS="quote">
just wanted to point out that the only way you are going to gain MPH out of a gear, is to change the gearing in the tranny (or get bigger tires/wheels)</TD></TR></TABLE>
didnt change a thing. i was shifting at 35mph, 65mph etc w/ that 4 speed. wasnt able to prior to gutting.
Old Apr 12, 2003 | 11:32 PM
Louie B.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ben Ogle &raquo;</TD></TR><TR><TD CLASS="quote">
Ben</TD></TR></TABLE>
I think I'm gonna be in a mod class anyway because I "swapped" a D16A6 from a 90 Si into my 91 Std
Old Apr 13, 2003 | 01:26 AM
ThatRicerDaniel's Avatar
whatever happen to the good old days of ppl wanting fast CLEAN street cars.is a gutted out honda with a d series motor really worth it? honestly . for that matter a gutted out honda with a b-series .. honestly. not tryin to hate just tryin to help some of the import world .. alot of imports are frowned on by local law agency's for some of these very reasons.
Old Apr 13, 2003 | 05:49 AM
Ben Ogle's Avatar
I think I'm gonna be in a mod class anyway because I "swapped" a D16A6 from a 90 Si into my 91 Std</TD></TR></TABLE>
That is legal for STS this year (street tire class with suspension work). Otherwise, with interior, you will be in street mod (motor and suspension work class) which is much more forgiving than an actual mod/prepared class (without interior) where there are cars that have absolutely nothing stock and very wide hoosiers.
Ben
Old Apr 13, 2003 | 07:19 PM
Urban Business
Guest
Posts: n/a
Default Re: so you want to gut your hatch....... heres some info (NitrousDreamz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousDreamz &raquo;</TD></TR><TR><TD CLASS="quote">whatever happen to the good old days of ppl wanting fast CLEAN street cars.is a gutted out honda with a d series motor really worth it? honestly . for that matter a gutted out honda with a b-series .. honestly. not tryin to hate just tryin to help some of the import world .. alot of imports are frowned on by local law agency's for some of these very reasons.</TD></TR></TABLE>
most local law agencys hate imports because they are driven by retarded teenagers who think every stop light it a race track, cant drive for ****, have loud stereos, endanger others.
gutted honda w/ a d series worth it: yes
b series: yes
boosted H22: yes
ive never had an officer get pissed bc i didnt have an interrior. then again ive only been pulled twice in the hatch, none of which were b/c of irradic driving speeding etc.
"clean" is nice, if i want to be comfortable i'll take the tahoe.
"nitrousDreams".... some of us dont need the juice to be quick.
Old Apr 13, 2003 | 07:34 PM
CimorelliCRX's Avatar
Well honestly I can say that in dallas cops look at my car that is gutted and will pull me over all the tiem. I get pulled over for anything and everything. And everytime, the cops ask me why my interior is gone. Most of it is from when the car was stolen, then I just gutted the rest. But I get pulled over and never get any tickets, but the cop always checks my vin to be the same as the one on the insurance card, and tells me its stolen car, lol. OR asks if it is. but yea I dont care, i rarely get tickets in taht car so its alright.
Old Apr 13, 2003 | 07:43 PM
FourthGenHatch's Avatar
Werd. When some state trooper nailed me it wasn't for no interior it was for my blinkers not working right and ricer related crap like that (in my case a harness wasn't plugged into the fuse box).
Old Apr 13, 2003 | 08:43 PM
thevtecnician's Avatar
i gutted my hatch too. I tokk out everything i could, seats, all interior, except roof lining. I even gutted my dash board( i could fit a nos bottle behind my glove compartment, and i even took out my center console, ill post pics when i get my homiez cam-
Old Apr 13, 2003 | 09:49 PM
Urban Business
Guest
Posts: n/a
Default Re: so you want to gut your hatch....... heres some info (thevtecnician)
ive had cops ask me why i didnt have an interrior. the water damage excuse works wonders. having a lack on interrior is not against the law. i dont see how a cop could use lack of an interrior as means to make a traffic stop.
"do you know why i pulled you over?"
"yes i was doing 38 over"
"no, you have no interrior"
"Bullshit, yes i do!"
Old Apr 14, 2003 | 01:14 AM
i think i could put down a 14 all motor. but yeah i rely on the bottle. no other way i have found in this world to go as fast for the same price. cuz we have all heard before .. in the words of that guy from that movie .. "Wining is wining"
