Question on determining if JDM ITR block is a JDM GSR block
Old Apr 11, 2003 | 07:29 PM
d0nkeyxPunch's Avatar
Banned
Default Question on determining if JDM ITR block is a JDM GSR block
How can you tell if the JDM Integra Type R block is not JDM Gsr block since the stamping is the same (B18C). Are there any markings that tell you which one is which? Doesn't it say P72 on the oil pan and the belts if its off of a JDM GSR? Please help me!!!
Old Apr 11, 2003 | 07:33 PM
bearingburner's Avatar
Default Re: Question on determining if JDM ITR block is a JDM GSR block (EM1b18cR)
hmm p72 is pretty much universal numbers. the pan are the same numbers on both. i guess you cant really tell. if you find out let me know also thanks
Old Apr 11, 2003 | 07:44 PM
Banned
Default Re: Question on determining if JDM ITR block is a JDM GSR block (bearingburner)
damn...they should have distinguishing marks so people can't get ripped off
Old Apr 11, 2003 | 08:17 PM
92TypeR's Avatar
FSAE
Both my R motors have P72 stamped on the oil pan.
Old Apr 11, 2003 | 09:02 PM
jonas's Avatar
cant tell from just the exterior of the block.
and mine says p72 on the oil pan as well.
how about you look at the pistons? header? whats all on this "block" that you're looking at?
Old Apr 11, 2003 | 11:34 PM
92TypeR's Avatar
FSAE
Default Re: Question on determining if JDM ITR block is a JDM GSR block (jonas)
If the head is off, see if the pistons are domed or flat.
Old Apr 12, 2003 | 10:16 AM
SiB16AVTEC's Avatar
Default Re: Question on determining if JDM ITR block is a JDM GSR block (92TypeR)
How about the intake manifold? Is it attached? Or are you just talking about the block itself? If so, don't the US/JDM GSR's use the same head, thus the same intake manifold? So you can check by that or try bolting on a b16a/type r manifold to see if that works if one isn't already on there. Hope that helps.
Old Apr 12, 2003 | 10:39 AM
slofu's Avatar
the heads are different, if you are speaking of a longblock, though i suppose someone could have swapped them. as someone else said, if the head is off, the jdm itr pistons will say p73-00, while the gsr pistons will say p72. they could have swapped the pistons, but then there's less difference yet. you can pull the oil pan and check the crank. the itr crank is fully counterweighted whereas the gsr is not, and itr rods have an 'R' on the side.
Old Apr 12, 2003 | 10:50 AM
skafia's Avatar
25 Year Member
Default Re: Question on determining if JDM ITR block is a JDM GSR block (slofu)
My friend's JDM ITR block was taken apart and the pistons said P73-00 on them. I guess that's the only other way to tell.
And his oil pan says P72 as well.
Old Apr 12, 2003 | 11:23 AM
Banned
Default Re: Question on determining if JDM ITR block is a JDM GSR block (skafia)
Thanks for all the responses to the post.
Old Apr 12, 2003 | 12:34 PM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">If the head is off, see if the pistons are domed or flat. </TD></TR></TABLE>
JDM p72 pistons are domed also. But theywill have p72 instead of p73 on them.
Old Apr 12, 2003 | 04:52 PM
b18c-rDC2's Avatar
Default Re: Question on determining if JDM ITR block is a JDM GSR block (sgT)
check the crank...counterweights on the itr crank are bigger/heavier than gsr...
Old Apr 12, 2003 | 07:30 PM
R you serious's Avatar
Default Re: Question on determining if JDM ITR block is a JDM GSR block (b18c-rDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c-rDC2 &raquo;</TD></TR><TR><TD CLASS="quote">check the crank...counterweights on the itr crank are bigger/heavier than gsr...</TD></TR></TABLE>
yeah. pull the oil pan and you can tell by looking at the crank, also, you might be able to know by looking at the pistons, if you know waht to look for
Old May 10, 2003 | 10:33 PM
msilbernagel's Avatar
The block will say P72, same as GSR, but the rods are stamped with an 'R', the pistons are P73, and the stiffener between the engine and tranny is a stouter 1-piece unit instead of the GSR's 2 piece one.
The heads will say P73...
Mark
Old May 11, 2003 | 12:27 AM
jonas's Avatar
Default Re: Question on determining if JDM ITR block is a JDM GSR block (msilbernagel)
WTF? wrong info, and you're bringing back a 1 month old topic.
Old May 11, 2003 | 12:58 AM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1b18cR &raquo;</TD></TR><TR><TD CLASS="quote">damn...they should have distinguishing marks so people can't get ripped off </TD></TR></TABLE>
i guess the R&D team for honda japan didnt expect the swap volume to be so high...everyone including their grandmas in a econobox hatchcrap wants a b18c...
Old May 11, 2003 | 09:40 AM
Default Re: Question on determining if JDM ITR block is a JDM GSR block (Soup ****)
Seems like the did like they often do, took one platform (GSR) and 'enhanced' it, so the foundation parts are common.
Does make it harder tho.
Curious as to what part the other poster thinks is wrong. I've got a JDM R in the garage (but, not a GSR) and the info comes from what I've seen on mine...
Mark
xchikon
Jan 29, 2014 06:30 AM
viciousef9
Mar 22, 2009 08:45 PM
ekx4
57
Oct 14, 2008 08:03 PM
Mini_Filip
Oct 7, 2008 12:31 AM
aznej2
Aug 25, 2007 02:24 PM
