Top speed of the EP3?
Old Apr 11, 2003 | 07:07 PM
Rhinoceros's Avatar
Default Top speed of the EP3?
whats the top speed?
Old Apr 11, 2003 | 08:58 PM
Asian Crocodile
Guest
Posts: n/a
Default Re: Top speed of the EP3? (Barking Owl)
130 easy more then likely, but the ECU might not allow it to reach those speeds
Old Apr 11, 2003 | 09:04 PM
Giant River Otter
Guest
Posts: n/a
Default Re: Top speed of the EP3? (Asian Crocodile)
yeah, I think the ECU will stop you from reaching top speed. I could be wrong.....
Old Apr 11, 2003 | 11:33 PM
anjapower's Avatar
Default Re: Top speed of the EP3? (Nismak)
in all seriousness, car & driver quotes it at 132, IIRC. People have reported 135+ but that could be just due to speedometer error.
Old Apr 12, 2003 | 04:38 AM
1 Special CTR's Avatar
Default Re: Top speed of the EP3? (anjapower)
okay i have EP3-R my top speed is 146+ 2 or 3 mph depends...
Old Apr 12, 2003 | 10:56 PM
taikahn's Avatar
Default Re: Top speed of the EP3? (1 Special CTR)
from what Ive heard --- USDM EP3 - Fuel Cut off at 137 mph
Ive done 115-120 in my ep3 no problem.
Old Apr 13, 2003 | 11:34 PM
PhxK20a3's Avatar
With the Hondata,the top speed SHOULD be 156 mph,but i HIGHLY doubt the car has enough guts to overcome drag.Id guess 136 give or take a few mph,on a stock redlined car
Old Apr 14, 2003 | 09:19 AM
My_Blk_Si's Avatar
Default Re: Top speed of the EP3? (PhxK20a3)
hit 134 and fuel cut off...not sure how acurate speedo is at those speeds but it read 134.
Old Apr 14, 2003 | 06:20 PM
chunky's Avatar
highest i've gone is a speedo indicated 135ish with some room left on the tach.
the theoretical top speed given stock gearing & redline is 145ish.
Old Apr 15, 2003 | 04:07 AM
pinota's Avatar
Default Re: (chunky)
Ok, here´s a portuguese speedo of a 2002 CTR.
Not bad !!! Also a mpeg. 270 Km/h = 167 MPH
Here´s the mpeg link:
http://www.we-todd-did-racing....3D%3D
Modified by pinota at 6:35 PM 4/15/2003
Old Apr 15, 2003 | 09:16 AM
Josh02Si's Avatar
Default Re: (pinota)
I hit 135 the other day i could have kept going but i chickened out! hahah
Old Apr 15, 2003 | 09:45 AM
Default Re: (Josh02Si)
what does the guy in portugese CTR have i wonder i wanna have the same thing!!!!!!!!!!!!!!1111
Old Apr 15, 2003 | 10:56 AM
that guy steveee's Avatar
Default Re: (1 Special CTR)
I have hit 138 bouncng off my rev imiter. Also that is going DOWN hill on a 4 lane high way. I have hit 135 on level ground. If I had hondata, with the 7700 rpm rev limit, it probably would pull to 145, but hp would still not be there to go any faster.
I have hit 135 about 7 times or more coming back from work.....its becoming at routine! Hahahahahahaha, just kidding
Old Apr 18, 2003 | 02:09 PM
aut0tek's Avatar
Default Re: (taikahn)
the USDM one has wayyy too short of a gearing to hit above 130... I don't care if your last name is Andretti it isn't going to go above 130 unless you're beyond the redline.
Old Apr 19, 2003 | 10:20 AM
lukas's Avatar
governed at 120
Jon_Accord
May 13, 2013 08:25 AM
Mr. DB2
Northeast (Sales)
May 3, 2012 07:13 PM
xiongtoua1990
Jun 21, 2008 10:35 AM
domepizzle
May 12, 2005 12:15 AM
93egsi
Jun 30, 2003 02:11 PM
