Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Give me a good reason NOT to buy this wheel for Autox
Old Apr 11, 2003 | 12:53 PM
YodaIsGod
Guest
Posts: n/a
Default Give me a good reason NOT to buy this wheel for Autox
Enkei TBS11
$100 ea at DiscountTire
this is for my IS300.
sounds like a good deal. 17x7 5x114.3 bolt pattern
just apprehensive about getting these
Old Apr 11, 2003 | 12:54 PM
PseudoRealityX's Avatar
Default Re: Give me a good reason NOT to buy this wheel for Autox (YodaIsGod)
It's not overly light, and they are really hard to clean if you care. I had a set on my protege for a few years.
Old Apr 11, 2003 | 08:25 PM
LudemanDan's Avatar
Staying in stock class (unless you don't care). If you want two wheelsets, run your stock wheels at races and use the new set for the street.
Dan
Old Apr 11, 2003 | 08:45 PM
577HondaPrelude's Avatar
Default Re: (LudemanDan)
because small Diameter and wide width are better for perfomance. Get 15" as wide as you can fit on your car
Old Apr 11, 2003 | 08:54 PM
Gennady's Avatar
New User
Default Re: (57STS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 57STS &raquo;</TD></TR><TR><TD CLASS="quote">because small Diameter and wide width are better for perfomance. Get 15" as wide as you can fit on your car </TD></TR></TABLE>
I disagree. Get the widest wheel that will fit the widest tire that will fit your car.
Old Apr 11, 2003 | 09:50 PM
Lo-Buck EF's Avatar
Default Re: (Wont be beat)
it depends what class u want to run in. i dont know if the is3 came with 17's, but if so those must be the same width as stockers to run them in stock. otherwise (as someone said) run the enki for street and stockers w/ R's for autox. if u want to run STX, then run the widest they allow (7 or 7.5)
-spenc
Old Apr 12, 2003 | 07:05 AM
EPrepCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudemanDan &raquo;</TD></TR><TR><TD CLASS="quote">Staying in stock class (unless you don't care). If you want two wheelsets, run your stock wheels at races and use the new set for the street.
Dan</TD></TR></TABLE>
Pretty wheels don't make ya fast.
I agree with Dan.
Old Apr 12, 2003 | 07:08 AM
Default Re: (SOLOef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I disagree. Get the widest wheel that will fit the widest tire that will fit your car.</TD></TR></TABLE>
I said to get wide width!! you don't need a big diameter to get wide width though, hell I know some cars run 15x9. Wide good, big diameter bad
Old Apr 12, 2003 | 09:15 AM
YodaIsGod
Guest
Posts: n/a
Default Re: (57STS)
i have to run 17's cause those are stock on my IS300
Need to stay in DS
Old Apr 13, 2003 | 02:37 PM
JustChou's Avatar
Default Re: (YodaIsGod)
They look pretty good to me. IS300's come with 7" tires? Sweet. Since they're the same diameter and width as your stock wheels, I'd recommend weighing both of them so you know you're running the lightest for autox.
Old Apr 13, 2003 | 05:08 PM
HybridFiend's Avatar
Default wheel weights?
http://www.scirocco16v.com/tech/wheelwieghts.htm Enkei TBS11 Cast 17x7 20.0
Old Apr 14, 2003 | 05:39 AM
Jake's Avatar
Default Re: wheel weights? (HybridFiend)
They look like those cheap "Z-Racing" wheels you can get at Sears.
Old Apr 14, 2003 | 06:12 AM
Gennady's Avatar
New User
Default Re: (57STS)
I said to get wide width!! you don't need a big diameter to get wide width though, hell I know some cars run 15x9. Wide good, big diameter bad </TD></TR></TABLE>
You missed my point. You said get the widest wheels you can fit. Well, I dont agree. Let me give you an example: Say your car can fit 7 inch wide rims along with 225 series tires without rubbing. I would suggest getting 6.5 inch rims that will still fit 225 series tires because you save on rim weight but mainting tire width.
Old Apr 14, 2003 | 07:26 AM
Philbert's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wont be beat &raquo;</TD></TR><TR><TD CLASS="quote">
You missed my point. You said get the widest wheels you can fit. Well, I dont agree. Let me give you an example: Say your car can fit 7 inch wide rims along with 225 series tires without rubbing. I would suggest getting 6.5 inch rims that will still fit 225 series tires because you save on rim weight but mainting tire width.</TD></TR></TABLE>
that really depends on what kind of tires you're running. hoosiers don't seem to mind being shoehorned onto a narrow rim. but almost any street tire will perform better on a wider rim.
Old Apr 14, 2003 | 08:58 AM
YodaIsGod
Guest
Posts: n/a
Default Re: (Philbert)
17x7 is what I need all around.
although, I think I can get away with 17x7.5 in the rear because it is stock for the IS300 SportCross wagon.
Old Apr 14, 2003 | 09:02 AM
Honda318dx's Avatar
I don't agree w/ you... Wider wheel is worth the extra .5lb Speads out the tire more, more even wear pattern...
Old Apr 14, 2003 | 09:26 AM
Pork Chop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YodaIsGod &raquo;</TD></TR><TR><TD CLASS="quote">17x7 is what I need all around.
although, I think I can get away with 17x7.5 in the rear because it is stock for the IS300 SportCross wagon. </TD></TR></TABLE>
Nope. You can't run 17x7.5 because it is not an option on the 4-door.
Old Apr 14, 2003 | 09:42 AM
YodaIsGod
Guest
Posts: n/a
Default Re: (Pork Chop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pork Chop &raquo;</TD></TR><TR><TD CLASS="quote">
DAMN!
oh well.....but wait, could I go, for some odd reason, go down to 16x7, because it was an option on the sedan. don't really want too. just fyi
Old Apr 14, 2003 | 09:52 AM
Evan55's Avatar
could I go, for some odd reason, go down to 16x7, because it was an option on the sedan. don't really want too. just fyi</TD></TR></TABLE>
not if it is a "dealer installed" option, which I believe it is.
Old Apr 14, 2003 | 10:10 AM
Pork Chop's Avatar
DAMN!
oh well.....but wait, could I go, for some odd reason, go down to 16x7, because it was an option on the sedan. don't really want too. just fyi</TD></TR></TABLE>
Well, if it was an option from the factory (not the dealer), then that would be ok. However, if the 16's required heated seats and the purple velvet interior, then you can't run 16's unless you have the heated seats and purple velvet interior.
Are you sure the optional wheels were 16x7? I would have sworn they were 16x6.5.
Just get those 17x7's. They're really cheap (can't beat $100/wheel!). They're not the lightest wheels out there, but in that price range, you can't be that picky. At 20 lb, I'll bet they're still a little lighter than those OEM bricks. Damn, those things were heavy!
Old Apr 14, 2003 | 11:58 AM
Gennady's Avatar
New User
Default Re: (Honda318dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">
I don't agree w/ you... Wider wheel is worth the extra .5lb Speads out the tire more, more even wear pattern... </TD></TR></TABLE>
I see you point.
MagneMike33
Honda Civic (2001 - 2005)
Jul 3, 2009 04:01 AM
kimokalihi
Sep 12, 2007 04:16 AM
eRACING
May 7, 2004 11:19 PM
Knestis
12
Apr 20, 2004 07:53 AM
honda25
Jul 11, 2003 11:30 AM
