valve spring install quick quest.
Old Apr 11, 2003 | 12:29 PM
JunIntegra's Avatar
Default valve spring install quick quest.
can you change valve springs and retainers without taking off the head on a b18c1??
Old Apr 11, 2003 | 12:32 PM
neo1z's Avatar
Default Re: valve spring install quick quest. (JunIntegra)
Yes, you can -- You need to get the Snap-On valvespring compressor in order to do so however.
Old Apr 11, 2003 | 12:33 PM
95GSRVtec
Guest
Posts: n/a
Default Re: valve spring install quick quest. (neo1z)
You also have to blow air down the sparkplug hole just incase you drop a valve!! Its not as easy as everybody might make you think!! GOOD LUCK
Old Apr 11, 2003 | 02:46 PM
JunIntegra's Avatar
Default Re: valve spring install quick quest. (95GSRVtec)
i dont understand. if you drop a valve while the motor is not on, whats the big deal?
Old Apr 11, 2003 | 02:57 PM
Blk98Teg's Avatar
Well your whole point was to not take the head off. If you drop a valve down the cylinder, you need to take the head off. You need to buy the adapter that screws into the spark pulg hole and hook it up to a compressor. This keeps it full of pressure and allows you to compress the spring w/o moving the valve.
Old Apr 11, 2003 | 03:01 PM
StinkyTofu's Avatar
Default Re: valve spring install quick quest. (Blk98Teg)
Can you put the piston at TDC so that when it falls, it doesn't fall all the way?
Old Apr 11, 2003 | 04:32 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: valve spring install quick quest. (StinkyTofu)
Only 2 cylinders will be on top at a time. So unless you plan on only taking apart the valvetrain on 2 cylinders, putting it all backtogether, then doing the other two, then you need to blow air into the cylinders, or what some people do is take some rope/string and push it thru the spark plug hole to fill up the space in the cylinder. I would probably put all cylinders at halfway thru the stroke and do that.
Old Apr 11, 2003 | 04:35 PM
95 integra's Avatar
Default Re: valve spring install quick quest. (PatrickGSR94)
I dont know how many miles are on the car, but you might want to go ahead and take the head off and replace the head gasket just for a little extra insurance.
Aaron M's Avatar
to much work, ill pay jeff to do mine
Old Apr 11, 2003 | 05:08 PM
B00ST2nR's Avatar
Default Re: valve spring install quick quest. (SilverB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">to much work, ill pay jeff to do mine </TD></TR></TABLE>
Like I did with my parts... I guess paying some people to do the work isn't so bad is it?
Old Apr 11, 2003 | 05:15 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Only 2 cylinders will be on top at a time. So unless you plan on only taking apart the valvetrain on 2 cylinders, putting it all backtogether, then doing the other two, then you need to blow air into the cylinders, or what some people do is take some rope/string and push it thru the spark plug hole to fill up the space in the cylinder. I would probably put all cylinders at halfway thru the stroke and do that.</TD></TR></TABLE>
I have changed valvespings and retainers on more than a couple of engines with the head on. I do one cylinder at a time, and rotate the piston in that cylinder to TDC when I do it. I use a leakdown tester to hold the valves up (it puts compressed air in the cylinder). I also put shop rags in the oil return ports to prevent keepers from falling in. Novice mechanics should not attempt this procedure, but an experienced hand should have little trouble.
Dxs
Jun 12, 2008 09:29 PM
90AccordVTEC
Jun 22, 2006 04:51 AM
r1de4life
Feb 7, 2006 09:02 AM
WhiteNess
Nov 7, 2005 05:04 AM
mycrx7
Sep 22, 2005 08:03 PM
