Help installing shift light....
Old Apr 11, 2003 | 11:11 AM
SiZ's Avatar
SiZ
Default Help installing shift light....
Hi.. I've got an Autometer Pro Lite shift light thats been sitting in my room for about 8 months, and I'm thinking its about time I get it out of the way and into my car..
Problem is, I don't know where I should connect the wire to get a tach signal.. Is there a wire on the back of the guage cluster that I can use, or do I have to run a wire into the engine bay? If I do that, where do I hook it to? I have what seems like 100 wires added under the hood for my swap, so its really confusing in there..
Anyone have any experience with these lights?
Thanks...
Old Apr 11, 2003 | 11:14 AM
Malgerus's Avatar
Default Re: Help installing shift light.... (SiZ)
You can run the wire to the tach signal wire that comes in to your gauge cluster. It's the only blue one there. OR you can splice it directly into the wire coming off the distributor, whichis also blue.
Old Apr 11, 2003 | 11:20 AM
SiZ's Avatar
SiZ
Default Re: Help installing shift light.... (Mr. S)
Thank you.
Old Apr 11, 2003 | 11:24 AM
Outsane's Avatar
What do you guys use a shift light for?
Do you need a light to tell you when to shift?
I have done a bit of hard shifting on tracks, and never needed a shift light..
Old Apr 11, 2003 | 11:27 AM
Malgerus's Avatar
Default Re: Help installing shift light.... (Outsane)
They're nifty... AND it came with my tach. AND it was cheaper to buy a tach WITH a shiftlight than one without one
Old Apr 11, 2003 | 11:57 AM
spankenstein's Avatar
It's one less thing to concentrate on. Instead of watching the tach for when to shift you are able to check other guges or concentrate more on driving. It becomes reflex to shift when the ligth comes on.
Wednesday I pulled three runs in a row that were within .001 of each other. A lot of that is due to shifting the same each time.
Old Apr 11, 2003 | 12:23 PM
15psi of fun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">What do you guys use a shift light for?</TD></TR></TABLE>
To tell us when to shift!!!
No i used to say that all the time why do you need a **** light but then i got a free one from a friend and i use it all the time. I would always look at my tach and not the road. Now i can see where im going becase im looking up. I use the connection on my MSD tach out put for my shift light. The blue wire on the distributor or down by the ECU will work.
The thing i like the most about it is i can look over at the person im racing as im leaving them and still shift becase i see the light out of the corner of my eye now thats the ****
pic for fun
Modified by EFrollingout at 10:23 PM 4/11/2003
Modified by EFrollingout at 11:26 PM 4/11/2003
Old Apr 11, 2003 | 01:23 PM
SiZ's Avatar
SiZ
I guess I don't really NEED one, but I really want to have one.. I mean, I've been alright without it so far.. (only hit the limiter once)
The thing I find is that the B16 just keeps charging faster as the RPM increases, so if I'm trying to look at the road and not watch my tach I like to know when I get to 8,000rpm.
Thanks guys.
Old Apr 11, 2003 | 01:30 PM
Outsane's Avatar
Really... OK.. I guess its only a drag thing..
And I love the placement of your shift light.. Not that I ever see myself with one but if I had to I would do it that way..
Old Apr 11, 2003 | 02:32 PM
spankenstein where you at KCIR i was out there what are you driven
civic-one
Mar 11, 2013 04:28 PM
Blacksole
Apr 30, 2010 05:48 PM
keith1054
Feb 21, 2009 11:23 AM
HandicapRacer
Jun 24, 2006 06:12 AM
redlinegsr
Nov 21, 2003 01:18 PM
