Return Fuel Line?
Old Apr 11, 2003 | 10:35 AM
My_Blk_Si's Avatar
Default Return Fuel Line?
I've read numerous times that the si's don't have return fuel lines...that's why you need a wet shot when using nitrous...
I have a friend who says if you're car is fuel injected you need a return fuel line...
something about stabalizing pressure or something...so unless you're carburated you have a return fuel line...
can someone clarify exactly how the fuel system works on the si's?
Old Apr 12, 2003 | 08:28 AM
APEXiTypeS's Avatar
Default Re: Return Fuel Line? (My_Blk_Si)
There is no return line for the rsx or the new si.
Old Apr 14, 2003 | 05:54 AM
hs2000's Avatar
Default Re: Return Fuel Line? (APEXiTypeS)
Extra pressure is relessed at the fuel pump in the tank (or maybe fuel pressure is controled by the amount of volts sent to the pump...I just read a artical about this in a issuse of Honda tuning, I love that mag) It is a new thing in cars not to have return lines. It was first seen in the focus. The idea behind it is that with a return line the fuel gets sent the engine bay and some of that fuel gets dumped back in to the tank but it is hotter now then it was before because of heat from the engine, so if there is no return line the fuel will stay cooler so you will get more power and have less smog, witch means that it will pass new smog laws.
Old Apr 14, 2003 | 09:04 AM
My_Blk_Si's Avatar
Default Re: Return Fuel Line? (hs2000)
Thanks for all the help...Time to go prove someone wrong...
Type-Spaz
Mar 30, 2011 02:12 PM
Rikaro
Sep 25, 2009 11:36 PM
DAmnquickDA
Jul 20, 2007 04:29 PM
The7thG
Honda Civic (2001 - 2005)
Mar 4, 2007 08:27 AM
