Whats All Needed To Put Slim radiator from EG into Ef ?
Old Apr 11, 2003 | 12:21 AM
STHPERFORMANCE's Avatar
Default Whats All Needed To Put Slim radiator from EG into Ef ?
As the topic says, i wanna do the 92-95 Civic Slim radiator in my 91 si hatch due to the fact i will be slapping a turbo kit on it..... <U>Exactly</U> what all is needed to have that radiator mounted in there nice and sound???? Also post some pics.. Thanks guys & girls
Old Apr 11, 2003 | 09:55 AM
Default Re: Whats All Needed To Put Slim radiator from EG into Ef ? (Outkast)
Anyone ????
Old Apr 11, 2003 | 10:05 AM
EL Vap133's Avatar
Place Racing makes a cross member that gives you the option of running a 92-95 civic radiator.
Old Apr 11, 2003 | 10:24 AM
Slimer89's Avatar
Default Re: Whats All Needed To Put Slim radiator from EG into Ef ? (Vap133)
Taking a guess here, but from looking at it, it seems that all you may have to do is fabricat some sort of mounts which should not be too hard to make it fit.
Old Apr 11, 2003 | 01:09 PM
Default Re: Whats All Needed To Put Slim radiator from EG into Ef ? (Slimer89)
Anyone other opinions ??
Old Apr 11, 2003 | 01:14 PM
See the silver metal bracket that connects the radiator to the radiator support. Is that the only bracket i will have to fabricate???
Old Apr 11, 2003 | 01:55 PM
Jeff C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast &raquo;</TD></TR><TR><TD CLASS="quote">
Anyone other opinions ?? </TD></TR></TABLE>
Neon rad1
Neon rad2
Neon rad3
So I hear.
Old Apr 16, 2003 | 11:38 AM
Slimer89's Avatar
Default Re: Whats All Needed To Put Slim radiator from EG into Ef ? (Jeff C)
I believe there is a mount on the bottom you have to fabricat as well, but that should be it.
Old Apr 16, 2003 | 11:44 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
i didnt try very long, but when i lined the radiator from my bro's 92 CX hatch in my 88 CRX, it was too tall to fit under the hood
Old Apr 16, 2003 | 02:30 PM
Donkey85's Avatar
Default Re: Whats All Needed To Put Slim radiator from EG into Ef ? (Y49CRXSIZC)
but wouldnt running a smaller radiator offer less cooling because its not as big. understand that u need the space for the turbo to go but then the motor would run hotter
Old Apr 16, 2003 | 06:53 PM
Default Re: Whats All Needed To Put Slim radiator from EG into Ef ? (Donkey85)
To the top.........
Old Apr 16, 2003 | 07:33 PM
hatchii's Avatar
the place racing cross member gives you the option of a 92-95 radiator? you sure? I want to make sure before i purchase one. Thanks!
Old Apr 17, 2003 | 05:32 AM
Slimer89's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 &raquo;</TD></TR><TR><TD CLASS="quote">but wouldnt running a smaller radiator offer less cooling because its not as big. understand that u need the space for the turbo to go but then the motor would run hotter</TD></TR></TABLE>
The radiator, if i am correct, is a little thicker. Not to metion the fact that EF's are over-cooled from the factory. Even with a b16 in my car, on my aftermarket engine temp gauge, it barely, if ever, reaches normal operating temperature.
Old Apr 17, 2003 | 05:37 AM
quis23's Avatar
http://breaka19.netfirms.com/bryan/bryan.html
Old Apr 17, 2003 | 05:44 AM
WuShu's Avatar
New User
Default Re: Whats All Needed To Put Slim radiator from EG into Ef ? (quis23)
http://www.geocities.com/neonradiator/neon.html
Old Apr 17, 2003 | 05:59 AM
JOEY F.'s Avatar
Also if you are running a D-series you can just swap your thermostat from an EG...opens a lil sooner to compensate for the EG's small rad. I would run this thermostat on hot autox days fer the extra cooling....kinda like a mugen thermostat but factory.
Old Apr 17, 2003 | 06:08 AM
WuShu's Avatar
New User
Default Re: Whats All Needed To Put Slim radiator from EG into Ef ? (JOEY F.)
These smaller radiators work perfectly, worried about cooling then just change your thermostat like someone said. My water temp gauge never goes beyond 210, and that is the max it has ever gone to with my neon rad. Jared was running this on a turbo setup and he had the exact same results, the second the fan turns on and the thermostat opens the circulating water and the fan are more than enough to cool.
Old Apr 17, 2003 | 06:18 AM
rioninja's Avatar
Default Re: Whats All Needed To Put Slim radiator from EG into Ef ? (HondaCRX)
Nice writeup mario.
Old Apr 20, 2003 | 04:38 PM
Default Re: Whats All Needed To Put Slim radiator from EG into Ef ? (rioninja)
i heard i can customize my stock crossmember to allow the 92-95 civic radiator to fit...... anyone done this?????????? what all do i need to customize?
Old Apr 20, 2003 | 09:08 PM
To The Top ????
teler86
36
Oct 30, 2011 08:51 AM
GasDreamz
11
Apr 11, 2009 01:45 PM
pat671
Jan 31, 2005 09:50 PM
wickedEFguy
May 5, 2004 02:40 PM
internet ay
Aug 28, 2002 02:22 PM
