Blown HG, Turbo D16y8 what to get:
Guest
Posts: n/a
Okay fellas, well shes toast. Anyway, what do you reccomend. OEM is the first thing that came to mind. But I hear things about cometic and so forth...any experiences suggestions. Also, plan on using honda OEM new head bolts. Any suggestions? Stock compression is fine. Which is chepr, OEM or ARP bolts?
I would use an OEM gasket with copper spray and ARP studs. This is what I'm running now. As for pricing, OEM bolts can be had for like $2 a piece, or $20 a set from Majestic, and ARP studs are like $120. I think it's worth it for the added strength and peace of mind. I would also double-net the studs and pre-torque them to 10-15ft-lb to make sure they seat evenly.
