Koni Yellows.... EP3
Old Apr 10, 2003 | 09:29 PM
NONKonformyst's Avatar
Default Koni Yellows.... EP3
Does anyone know of a release date for Koni's EP lineup? What about any other companies? The only things I've seen so far are full coilovers and some type of adapter kits. I really don't feel like running stock shocks like a lot of people here and on ephatch.com are. Any info would be appreciated.
George, I know you must have something to tell me about this.
Old Apr 10, 2003 | 09:55 PM
chunky's Avatar
Default Re: Koni Yellows.... EP3 (95redLUDE)
koni already makes rear shocks for the ep3. for the front, the koni inserts require destroying the stock struts to accomodate the koni inserts.
that is the main reason why i'm staying away from koni for now. I'm sure someone will make a replacement strut for the front suspension so that modifying the stock strut isn't necessary.
either that or coilovers.
Old Apr 11, 2003 | 12:42 PM
EddieHatchBlack's Avatar
Default Re: Koni Yellows.... EP3 (chunky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunky &raquo;</TD></TR><TR><TD CLASS="quote">
either that or coilovers.</TD></TR></TABLE>
Tein is about to come out with their BASICS line. On their site it only says $950 USD. Not bad at all.
Old Apr 11, 2003 | 02:27 PM
SMZ GSR's Avatar
Default Re: Koni Yellows.... EP3 (Eddie HatchBlack)
i believe tein already came out with their crazy electronic controlled suspension for the EP. options has it already listed and i believe jdmhondaparts has it on their car
Old Aug 28, 2004 | 07:20 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: Koni Yellows.... EP3 (NONKonformyst)
Uh oh.
Does anybody know about the Koni Yellow that are currently shipping as '02-'04 "CTR" struts?
I'm assuming that since they were listed with a separate part number form the 7 Gen Civic that Koni is making struts specifically for the EP3.
I hope I'm right...can anybody confirm this?
I broke a Mugen/Showa strut and nobody can tell me how to buy just the front struts instead of all four coilover strut/spring combinations, so I'm getting Koni to try out.
Old Aug 28, 2004 | 07:27 PM
H-T Order of Merit
Default Re: Koni Yellows.... EP3 (George Knighton)
8641-1416 &lt;-That's the part number that people seemed to be having trouble with.
Maybe I've lucked out. The part number for the struts I've ordered are 8610-1415(Sport) and the description shows as "Koni Adjustable Yellow Shock for 01-03 Civic EP3 Type R (Front)."
Old Aug 28, 2004 | 07:59 PM
Battle Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">8641-1416 &lt;-That's the part number that people seemed to be having trouble with.
Maybe I've lucked out. The part number for the struts I've ordered are 8610-1415(Sport) and the description shows as "Koni Adjustable Yellow Shock for 01-03 Civic EP3 Type R (Front)."</TD></TR></TABLE>
it depends if the ep3 you have has the bigger strut housing....around the middle of 02-03 and on, they (honda) changed the strut for the bigger one like the type s...did you measure the outside diameter of the strut housing to make sure you ordered the right koni insert?
Old Aug 29, 2004 | 05:22 AM
H-T Order of Merit
Default Re: Koni Yellows.... EP3 (02SilverSiHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02SilverSiHB &raquo;</TD></TR><TR><TD CLASS="quote">
....around the middle of 02-03 and on, they (honda) changed the strut for the bigger one like the type s...did you measure the outside diameter of the strut housing to make sure you ordered the right koni insert?</TD></TR></TABLE>
Nobody ever asked about that. I assumed it was a whole strut, minus spring. If it's an insert, I'm not sure I even want them.
I might be OK, because I have a Mugen strut currently installed, and I still have the old strut that came off the car.
Old Aug 29, 2004 | 05:42 AM
I might be OK, because I have a Mugen strut currently installed, and I still have the old strut that came off the car.</TD></TR></TABLE>
yeah, that's all koni makes for the dc5s and ep3's. I sent you back a pm
Old Aug 30, 2004 | 03:24 PM
Jimmer's Avatar
I broke a Mugen/Showa strut and nobody can tell me how to buy just the front struts instead of all four coilover strut/spring combinations, so I'm getting Koni to try out.</TD></TR></TABLE>
Wow, this statement really worries me. I just purchased a set from King and installed them, how is it that you broke this strut? Isn't there some sort of warranty for this product?
Old Aug 30, 2004 | 04:56 PM
03ephatch's Avatar
Default Re: Koni Yellows.... EP3 (LHD_EP3)
guys, a great fallback on imported products under warranty(if they have no repair/ performance shop connected here from overseas) is... more likely the shop you bought it from, might have to contact them overseas.
just like my situation with D2. it took them 2 weeks just for 1 question(eventhough they did just start supplying stateside). now that i have the "go" signal, my car's back with me.
Old Aug 30, 2004 | 05:06 PM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LHD_EP3 &raquo;</TD></TR><TR><TD CLASS="quote">
Wow, this statement really worries me. I just purchased a set from King and installed them, how is it that you broke this strut? Isn't there some sort of warranty for this product?</TD></TR></TABLE>
It's really not a warranty problem.
It looks like pothole damage. The right front strut's shaft looks like it was slightly bent, and as the months went by it slowly wore against the seals inside the damper until it went bad. This past winter in NoVA was kind of bad for road repairs.
I do have an email from King Motorsports asking me about whether I wanted to warranty it. However, after looking at the strut, it's just not fair to call it a warranty issue.
They had to write Mugen to ask how to buy one or two struts instead of four, and it has been a while since then, so I'm assuming the worst and looking for alternatives.
There is no fault in King Motorsports here. There's every sign that they would've taken care of it if the damper had failed without help.
Old Aug 30, 2004 | 05:22 PM
Jimmer's Avatar
There is no fault in King Motorsports here. There's every sign that they would've taken care of it if the damper had failed without help. </TD></TR></TABLE>
No worries then, I understand.
Old Aug 30, 2004 | 05:34 PM
No worries then, I understand.</TD></TR></TABLE>
Watch out for those pot holes you always hit
Old Aug 30, 2004 | 06:35 PM
H-T Order of Merit
They were pretty hard to avoid this past winter.
Old Aug 30, 2004 | 08:03 PM
03ephatch's Avatar
hopefully they didn't keep you back from your other options. regards.
Old Aug 31, 2004 | 11:19 PM
iRRATiONAL's Avatar
SO anyword on these being a full strut or are they inserts?
Old Sep 1, 2004 | 02:29 AM
Default Re: Koni Yellows.... EP3 (iRRATi0NAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iRRATi0NAL &raquo;</TD></TR><TR><TD CLASS="quote">
SO anyword on these being a full strut or are they inserts?</TD></TR></TABLE>
they are inserts....I have them. The front are just your regular full strut
Old Sep 1, 2004 | 03:47 AM
H-T Order of Merit
Yup. Even the newest part number is still just an insert, and I don't think I want to go through all that.
Cancelled the order and looking around for something else.
paul_os
Suspension & Brakes
11
May 27, 2011 09:49 AM
GradyDC5
Apr 15, 2004 11:33 AM
ACR
May 4, 2003 12:35 AM
lsteggy
Jan 30, 2003 07:16 PM
Ohlias
Feb 26, 2002 09:30 AM
