Which rims and suspension?
Ok, I am about to get some rims and suspension. First off, would Koni Yellows and Eibach Ground Controls be a good combination? Or would it be better to just get springs and shocks? Also, do you think I will need a camber kit? what size rims do you think I should get? 16s or 17s? Also, I can't decide between some Tenzo Shu 4s, or Velox VX 8rs? Both gunmetal w/ polished lip. I have a green teg, so what do you think will look better? And what kind of tires should I get? Sorry for all the questions, but I need to know soon. Thanks.
IMO Tenzo Shu are nice. Definately 17" for bing-bling purposes. About tires...that depends on how safe you drive and the roads you drive on. Majority of people like 205/45/17 some might go with 215/45/17. I would stay away from 40 series tires because I think there is not too much appearance difference from 40 vs 45 series only the 40 series are very thin.
ground control and koni yellow is an excellent combination. for the rims thats more of an appearance/cosmetic issue. I believe that tein has come out with a basic coilover which would cost about the same or even less than the gc/ky combo,I would look into that as well.
