wiring gurus i need your help!
Old Apr 10, 2003 | 05:54 PM
2trix's Avatar
Default wiring gurus i need your help!
anyone know exactly how to wire a obd1 dist to a obd2 harness!?
i need to know wire color to wire color?
more specificly h22 jdm 2 plug dist to obd2 96 civic dx harness...
thank you!
Old Apr 10, 2003 | 08:39 PM
poison's Avatar
Default Re: wiring gurus i need your help! (2trix)
Hmm...I know of converting from OBD2 to OBD1, but I'm not sure of the other way around.
If I remember correctly, take your 96 civic plug off the distributor, and cut it off. You will need to use the OBD2 plug.
On the JDM H22 distributor being OBD1, cut off the OBD1 plug, and match the colors to the Civic OBD2 plug onto the Distributor.
If I am wrong, please someone correct me, other than that, I would take a load off and purchase an OBD2 dist from an accord (F22 sohc vtec)
Old Apr 10, 2003 | 08:56 PM
MR2T32's Avatar
Default Re: wiring gurus i need your help! (poison)
this probably nothing helpful, but i would just stay with ODBI.
Old Apr 11, 2003 | 09:11 AM
2trix's Avatar
Default Re: wiring gurus i need your help! (AccordH22A32)
well i do have a obd2 ecu....so with the obd1 dist wouldnt i need to change to dizzy or whater to obd2!? im havin some major porblems and i think obd1 is gonna be the way to get out of em.....DAM YOU HONDA!
90civicgsr
Apr 8, 2008 07:23 PM
speedrcr24
Feb 27, 2005 07:16 PM
mtber
Jul 14, 2003 08:05 PM
