What do you guy's do to prevent pipes from seperating while boosting?
Old Apr 10, 2003 | 05:07 PM
turbo Si's Avatar
Default What do you guy's do to prevent pipes from seperating while boosting?
I have DRAG III piping and it sucks. Under high boost the pipes, especially the pipes between the turbo and the intercooler, always begin to seperate! What are solutions to prevent this? I was thinking of sanding the the chrome where the couplings go over?
HELP
Old Apr 10, 2003 | 05:18 PM
smallttocs's Avatar
Default Re: What do you guy's do to prevent pipes from seperating while boosting? (turbo Si)
weld that bitch!
Old Apr 10, 2003 | 05:20 PM
TeStUdO's Avatar
Default Re: What do you guy's do to prevent pipes from seperating while boosting? (smallttocs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smallttocs &raquo;</TD></TR><TR><TD CLASS="quote">weld that bitch! </TD></TR></TABLE>
there is a good answer, sanding down the end will work decent but nothing like welding
Old Apr 10, 2003 | 05:21 PM
Aeka GSR's Avatar
New User
double up on clamps?
Old Apr 10, 2003 | 05:28 PM
boosted hybrid's Avatar
I had this problem for awhile. Here is three solutions that will work very well:
1. Weld a lip, or bead around the ends of the pipes. Its give the coupler and hose clamp something to resist against, instead of just using friction and pressure of the normal surface of the pipe.
2. T-bolts clamps. These will make a huge difference. You can put a more even pressure distribution around the pipe, therefore keeping the piping on better. Also, you can generate more pressure onto the piping with the t-bolt clamps over the conventional hose clamp since they are made alot stronger.
3. Use super long piece of coupler so you can double clamp with t-bolt clamps. You'll have more surface pressure distribution with two clamps, and the longer coupler.
Check out mcmaster-carr for t-bolt clamps and nitrile coupling.
http://www.mcmaster.com/
Type "196" in the seach catagory for the coupling. Type "hose clamps" in the search for t-bolt clamps. You wont find cheaper prices on these two items anywhere else.
Old Apr 10, 2003 | 05:40 PM
ekb18c's Avatar
Default Re: What do you guy's do to prevent pipes from seperating while boosting? (boosted hybrid)
T-bolt clamps makes a huge difference........
Old Apr 10, 2003 | 05:44 PM
SiR Kid's Avatar
New User
Default Re: What do you guy's do to prevent pipes from seperating while boosting? (ekb18c)
If you're done modifying your setup, and just want them to stay put, Hairspray the piping, then slide the silicone coupler on. When the hairspray dries, it's harder to separate then a 10 year old waterneck!
Old Apr 10, 2003 | 05:54 PM
turbo Si's Avatar
Default Re: What do you guy's do to prevent pipes from seperating while boosting? (SiR Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">If you're done modifying your setup, and just want them to stay put, Hairspray the piping, then slide the silicone coupler on. When the hairspray dries, it's harder to separate then a 10 year old waterneck! </TD></TR></TABLE>
That's funny, I was actually thinking of using some 3M residue but was not sure how difficult it would be to seperate when i want to take out the piping. Welding was a solution that I had, and so was the T-Bolt clamps but I never knew they made that much of a difference!
Are T-Bolt clamps the same clamps that Turbonetics sell?
Also, what's the difference between T-Bolt clamps and Vband-Clamps? Aren't they the same?
Old Apr 10, 2003 | 06:02 PM
turbo Si's Avatar
Damn.....that mcmaster.com has some nice stuff. I was looking at those High-Torque Worm-Drive Hose Clamps, and the T-Bolt Hose Clamps.
Which do yall think?
Old Apr 10, 2003 | 08:58 PM
intekragsr's Avatar
try hondabond on the pipe ends. Let it dry, then put the coupler on.
Old Apr 10, 2003 | 09:07 PM
ludelvr's Avatar
Default Re: What do you guy's do to prevent pipes from seperating while boosting? (intekragsr)
On one kit I did, I didn't have access to welder or a beading machine so I just used self tapping screws on either side of the charge piping near the end and it's as good as welding a small bead on the same place.
turbod16y8's Avatar
i used the orange silicone stuff that they have at autozone. holds up good. i think its called hi tempature silicone. when i tried taking it off it was tough but it came off eventually.
Old Apr 10, 2003 | 09:09 PM
Sprockets's Avatar
This just bought a bunch of constant torque clamps for my aluminum piping, otherwise I would've gotten T bolts and spring loaded T bolt clamps. This place has excellent prices-
http://www.partssystems.com/sh...id=28
Old Apr 10, 2003 | 09:43 PM
B18EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">I had this problem for awhile. Here is three solutions that will work very well:
Which hoses are the best? the nitrile ones, buna n, silicone coolant, or silicone rubber ones?
Old Apr 10, 2003 | 09:44 PM
CheezeFrog's Avatar
Default Re: What do you guy's do to prevent pipes from seperating while boosting? (Evil Beaver)
Get motor mount inserts too. When your engine rocks back & forth under load, that'll put a lot of stress on the pipe couplers.
Old Apr 11, 2003 | 03:30 AM
turbo Si's Avatar
Default Re: What do you guy's do to prevent pipes from seperating while boosting? (CheezeFrog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CheezeFrog &raquo;</TD></TR><TR><TD CLASS="quote">Get motor mount inserts too. When your engine rocks back & forth under load, that'll put a lot of stress on the pipe couplers.</TD></TR></TABLE>
Yeah your right. I've had the Energy suspension polturethane inserts since my first clutch replacement! I'm gonna look into welding small beeds, and getting better hose clamps. Like someone asked before me, which hoses are the best? I was wondering this myself. Also can anyone post a pic of welding beeds on the pipe just so i can see what you guys are talking about exactly!
Thank's for the great info guys!
Old Apr 11, 2003 | 03:38 AM
Default Re: What do you guy's do to prevent pipes from seperating while boosting? (B18EG6)
Nitrile, then silicone.
Old Apr 11, 2003 | 04:40 AM
Charlie Moua's Avatar
JB weld it!!!!! solves mostly everything!
Old Apr 11, 2003 | 12:39 PM
SEFIxCivic's Avatar
if you cant afford to weld a bead on the pipe, u shoulda take a pair of vice grips and bend a lip at the ends of the pipes. doesn't look very good, but it will be covered by the coupler and no one but you will know.
Old Apr 11, 2003 | 04:10 PM
turbo Si's Avatar
Default Re: What do you guy's do to prevent pipes from seperating while boosting? (SEFI8LOxCivic)
My friend gave me a good idea. He went to a Van's skate park and bought a strip of the sand paper like stuff they stick onto skateboards so your shoes will grip. I think it's gonna work out pretty well. I will also get a set of T-Bolt clamps. At those prces I might as well!
Old Apr 11, 2003 | 04:45 PM
Agtronic's Avatar
I would definitely weld a lip at the end of each pipe!
Old Apr 11, 2003 | 04:49 PM
VaporTrail's Avatar
New User
Default Re: What do you guy's do to prevent pipes from seperating while boosting? (Agtronic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agtronic &raquo;</TD></TR><TR><TD CLASS="quote">I would definitely weld a lip at the end of each pipe! </TD></TR></TABLE>
Bead welding holds up well, but for those of you without a welder, JB weld nipples around the end of the pipe, works just as well. Of course you should always try to minimize couplings whenever possible by welding joints together.
Old Apr 11, 2003 | 05:11 PM
Agtronic's Avatar
Default Re: What do you guy's do to prevent pipes from seperating while boosting? (VaporTrail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VaporTrail &raquo;</TD></TR><TR><TD CLASS="quote">Bead welding holds up well, but for those of you without a welder, JB weld nipples around the end of the pipe, works just as well. Of course you should always try to minimize couplings whenever possible by welding joints together.</TD></TR></TABLE>
True, I always forget that. I used to always get mad when people told me "just weld it" before I bought a welder ...
Old Apr 11, 2003 | 05:12 PM
DamonBoost's Avatar
New User
And make sure to minizmize the gap between the two pipes as much as possible if using a coupler..
Old Apr 11, 2003 | 05:42 PM
KStuned's Avatar
Default Re: What do you guy's do to prevent pipes from seperating while boosting? (DamonBoost)
I use these trick weld-on intercooler connectors, never even had a connector try and blow apart!
