gsr cluster in and working but some probs
Old Apr 10, 2003 | 04:21 PM
crx8psi's Avatar
Default gsr cluster in and working but some probs
Ok I got my gsr cluster in my 88 hatch and have everything hooked up even the vss. Ok now here is my problem, turn key to acc or even start the car the speedo jumps to 40mph then when I start moving it goes up from there. Also it is still throwing a code 17 vss code WHY? If me removing the needle has anything to do with it being at 40 mph just let me know. But why amI getting this code? Any help is appreciated and thanks in advance.
Old Apr 10, 2003 | 05:32 PM
ghettocrxsi's Avatar
Default Re: gsr cluster in and working but some probs (b16a88hatch)
is it hooked up the the vss wire going to the ecu? that could be your problem.
Or you just need to reset your ecu.
Also u moving your needle probably did mess something up. Just reset your ecu and it should be ok
Old Apr 10, 2003 | 08:06 PM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
try this:
Black= make sure it's good ground
yellow/blue= power (connect this to a yellow wire inside your stock harness)
yellow/white= signal (connect this to b6 orange wire from GSR plug)
Reconnect b11 to a power source and connect b6 to the signal from the VSS.
Old Apr 10, 2003 | 08:41 PM
crx8psi's Avatar
Default Re: gsr cluster in and working but some probs (MR.RED'89)
Ok here is how my vss is hooked up.
Black=ground
Yellow/blue is hooked up in the fuse box to a power
Yellow/white is hooked to the orange wire
Why did you say reconnect b11 to power source i never switched it or disconnected it?
Old Apr 30, 2003 | 03:22 PM
Audipwr1's Avatar
did yours all come with harnesses?
jdmef69
May 5, 2012 08:19 AM
Egpower88
Jul 29, 2010 06:10 AM
2000CivicEK
11
Jun 18, 2009 05:50 PM
chad
Apr 13, 2009 06:43 PM
EF-21
Mar 15, 2004 04:51 PM
