oil in my coolant reservoir
I just had my head recently put on and my arp head studs installed...i think the arp studs have to be re-torqued to 70 lbs correct. Could this be the problem to the oil in coolant reservoir? Do i have to replace my coolant and add new coolant in after i re-torque the head? Do i need a new headgasket? i put in a mugen headgasket and dont want to waste it...thanks for any info
Yes, you'll need a new headgasket and I highly recommend torquing the head bolts to spec so coolant and oil does not go to the wrong lines inside the block.
You may re-use the headgasket, as long as its in good condition. I would clean it up and wash the whole system out by draining all oil and coolant after you have torqued down the head bolts.
HTH.
HTH.
oh ya thats the head gasket......have the head checked and resurfaced if needed.....honda head gaskets are around 60-70 bucks....take a nice warm sunday and change it out....and you might want to look check into new head bolts...ive never reused them...for fear or them being stretched...good luck
I never reuse headgaskets either... Tho i'm sure it will be fine with a little copperspray I just like having a new gasket... NO MATTER how many times you rip apart the motor... $60 isn't too bad!! I'm sure TimoneX will be in here soon... he always seems to find the same posts I do about reusing headgaskets... It's all good tho, we all have our own opinions... Latez
