Hose coming out of EG firewall, what is it? Pics inside!
Old Apr 10, 2003 | 12:03 PM
Fuster_Cluck's Avatar
Default Hose coming out of EG firewall, what is it? Pics inside!
What is this hose coming out the firewall?
Car: 93 Civic Cx (hatch)
Motor: 98 GSR
On my friends Eg (93) / GSR (98) hatch the hose is NOT there:
I'm assuming I do NOT need it. But, I would just like to know what hose this is.
Old Apr 10, 2003 | 12:05 PM
kikicamacho's Avatar
Default Re: Hose coming out of EG firewall, what is it? Pics inside! (Hybrid93Hatch)
It's where you add blinker fluid.
Or a/c drain.
Old Apr 10, 2003 | 12:08 PM
sikciv666's Avatar
kind of looks like a heater hose.....
Old Apr 10, 2003 | 12:10 PM
Default Re: Hose coming out of EG firewall, what is it? Pics inside! (sikciv666)
Can someone with an Eg go outside and take a look for me?
Thanks!
Old Apr 10, 2003 | 12:12 PM
10seconds's Avatar
Honda-Tech User
Default Re: Hose coming out of EG firewall, what is it? Pics inside! (jcamacho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcamacho &raquo;</TD></TR><TR><TD CLASS="quote">It's where you add blinker fluid.
Or a/c drain.</TD></TR></TABLE>
LMAO
Old Apr 10, 2003 | 12:16 PM
martilafox's Avatar
New User
Default Re: Hose coming out of EG firewall, what is it? Pics inside! (10seconds)
I believe it has something to do with the emissions. As far as I know, it will not "hurt" anything in your engine. I believe you don't even need that canister hooked up at all
Old Apr 10, 2003 | 12:19 PM
Someone said the same thing on another board. I'll probably just leave it and let it hang
Old Apr 10, 2003 | 12:24 PM
I'll check my eg for you during my next break. 90 minutes from now.
Old Apr 10, 2003 | 12:41 PM
riot's Avatar
AC Drain...KEEP IT if you have and use AC in your car. Without that, all of the condensation will accumulate under your dash and essentially flood your carpet.
-ryan
Old Apr 10, 2003 | 12:44 PM
Soled Out's Avatar
I dont have that hose either so i'd assume your ok without it if your not going to run AC.
Old Apr 10, 2003 | 01:42 PM
92sleepR's Avatar
New User
A/C drain hose. absolutly no doubt what so ever.
Mike
Old Apr 10, 2003 | 01:53 PM
Stryker908's Avatar
Default Re: Hose coming out of EG firewall, what is it? Pics inside! (92sleepR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92sleepR &raquo;</TD></TR><TR><TD CLASS="quote">A/C drain hose. absolutly no doubt what so ever.
Mike</TD></TR></TABLE>
Yep
Old Apr 10, 2003 | 03:19 PM
sleeperb's Avatar
a/c drain definitely, but shouldnt it be facing the ground?!
Old Apr 10, 2003 | 03:31 PM
slomofo's Avatar
GDD Member
Default Re: Hose coming out of EG firewall, what is it? Pics inside! (martilafox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by martilafox &raquo;</TD></TR><TR><TD CLASS="quote">I believe it has something to do with the emissions. As far as I know, it will not "hurt" anything in your engine. I believe you don't even need that canister hooked up at all </TD></TR></TABLE>
The canister is something worth keeping.
Here's what it does for carbeurated cars, I think it's similar to EFI cars.The fuel tank is sealed to prevent hydrocarbons (unburned fuel) from escaping, the gas cap is in place to hold pressure and there is a pressure relief valve that regulates the amount of pressure in the tank. When the tank pressure is too high, the pressure relief valve opens and lets excessive pressure/hydrocarbons into the charcoal canister for storage. When the engine warms up and is at cruising speed, the canister is purged by engine vaccuum and the stored hydrocarbons leave the canister and enter your intake manifold so that your car doesn't lean out.
Probably more than you needed to know, but i'm bored.
Old Apr 10, 2003 | 04:57 PM
90accord1's Avatar
Default Re: Hose coming out of EG firewall, what is it? Pics inside! (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">
Probably more than you needed to know, but i'm bored.</TD></TR></TABLE>
i think its not so much for leaning out but more so emmisions, hence pushing it into the intake manifold to be burner by the engine again.
cubanteg16
Sep 3, 2009 10:38 PM
Jipsychris
May 10, 2008 09:13 AM
B18CivicEH2
Dec 31, 2006 01:01 PM
JBG's Ferio
May 1, 2003 08:11 AM
yellowbastrd
Apr 18, 2002 06:19 PM
