How to adjust cam gears
Old Apr 10, 2003 | 10:39 AM
Mr.Integra's Avatar
Default How to adjust cam gears
If i want to advance the intake cam, do i turn the cam gear right or left?
If i want to advance the exhaust cam, do i turn the cam gear right or left?
TIA
Old Apr 10, 2003 | 10:45 AM
psi420's Avatar
Default Re: How to adjust cam gears (Mr.Integra)
Your cam gear should be marked which way to turn em.
pills_PMD's Avatar
what gears are you using? it should be marked.
http://www.hondaswap.com/articles/viewer.php?id=28
that may help
Old Apr 10, 2003 | 10:52 AM
Mr.Integra's Avatar
Default Re: How to adjust cam gears (pills_PMD)
i know how to adjust them.. I am just not sure which way to rotate the cam gears for advancing or retarding..
Do i rotate clockwise when advancing the intake cam?
Do i rotate clockwise when advancing the exhaust cam?
Just answer each question with a yes or no, then i can figure it out. Thanks!
Old Apr 10, 2003 | 10:54 AM
psi420's Avatar
Advance = Clockwise
Retard = Counter Clockwise
If you are not using adjustable cam gears, each tooth is 20 crank º.
Modified by psi420 at 12:47 PM 4/10/2003
Old Apr 10, 2003 | 01:32 PM
Mr.Integra's Avatar
Default Re: How to adjust cam gears (psi420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 &raquo;</TD></TR><TR><TD CLASS="quote">Advance = Clockwise
Modified by psi420 at 12:47 PM 4/10/2003</TD></TR></TABLE>
http://godspeed.hack.net/camgeardirections.html has the other way around.
Old Apr 10, 2003 | 01:39 PM
psi420's Avatar
I read it off of my CAM GEAR on my car.
That is an AEM Cam Gear BTW.
Want a picture?
Quote from Website you posted:
This is how the belt and gears will look once installed. Belt moves in counter-clockwise direction. Moving outer gear towards the right will advance cam timing and moving outer gear to left will retard. Always remember to reset timing when adjusting intake gear.
TurboB16A300Hpteg
Jun 9, 2008 10:44 AM
johnclaunch
Apr 3, 2008 09:27 AM
nutball72
Aug 21, 2006 01:47 PM
berkel
Aug 9, 2001 06:23 AM
