Difference in GSR and SiR B18c?
Old Apr 10, 2003 | 10:05 AM
steadyeddy's Avatar
Default Difference in GSR and SiR B18c?
What, if any, is the difference in the GSR b18c and the SiR b18c?
I'm looking for a b18c1 motor and some are advertised one way and some the other.
Thanks
Old Apr 10, 2003 | 10:09 AM
Hybrid Beast's Avatar
Default Re: Difference in GSR and SiR B18c? (steadyeddy)
GSR B18C is JDM and i think the Sir is canadian or european. pretty sure the B18C gsr motor has more hp
Old Apr 10, 2003 | 06:48 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steadyeddy &raquo;</TD></TR><TR><TD CLASS="quote">What, if any, is the difference in the GSR b18c and the SiR b18c?
Thanks </TD></TR></TABLE>
GS-R b18c1 is a usdm 170hp 10.0:1 compression ( could be 10.2) I might be wrong.
Sir-G b18c is a jdm 180 hp 10.4:1 compression
both has same gear ratio but in the jdm b18c you can get a optional factory lsd where the usdm b18c won't have it.
That's all I can think of right now though.
Old Apr 10, 2003 | 06:49 PM
Default Re: Difference in GSR and SiR B18c? (Hybrid Beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Beast &raquo;</TD></TR><TR><TD CLASS="quote">GSR B18C is JDM and i think the Sir is canadian or european. pretty sure the B18C gsr motor has more hp</TD></TR></TABLE>
Old Apr 11, 2003 | 05:02 AM
SlowWhiteEvo's Avatar
Default Re: Difference in GSR and SiR B18c? (sleeperciv)
actually JDM gs-r is 10.6:1 c/r
Old Apr 11, 2003 | 08:04 AM
hypa's Avatar
Default Re: Difference in GSR and SiR B18c? (SlowRedHybrid)
Since when did any civic come with a b18 motor?!?
The EK chassis SiR is the Canadian version of the USDM Si. It's also powered by the same b16a2 as the USDM Si.
Old Apr 11, 2003 | 09:06 AM
steadyeddy's Avatar
Default Re: Difference in GSR and SiR B18c? (hypa)
We're talking about an Integra Sir-G b18c...not a civic.
And, thanks Sleeperciv for the information.
Old Apr 11, 2003 | 09:11 AM
Jonathan_ED3's Avatar
nobody ever said anything about a Civic.
Old Apr 11, 2003 | 09:51 AM
VTECVillain's Avatar
USDM B18C1 GSR = 10.0:1 170hp
JDM B18C SiR = 10.6:1 180hp
The JDM ECU has a speed governor and some years (96+ I believe) have no VTEC pressure switch.
Old Apr 11, 2003 | 10:00 AM
wuhungsixxx's Avatar
New User
Default Re: Difference in GSR and SiR B18c? (VTECVillain)
JDM B18C can also be had in a Automatic version...i should know...i still have the auto tranny sitting in my backyard
Old Apr 11, 2003 | 10:14 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
The JDM ECU has a speed governor and some years (96+ I believe) have no VTEC pressure switch.</TD></TR></TABLE>
The OBD1 JDM P72 ecu's facotry programming sucks *** too. If you get a JDM B18C-SiR/G engine either upgrade the ecu or use a stock US OBD1 P72 ecu.
Old Apr 11, 2003 | 03:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowRedHybrid &raquo;</TD></TR><TR><TD CLASS="quote">actually JDM gs-r is 10.6:1 c/r</TD></TR></TABLE>
thanks for the correction
Old Apr 11, 2003 | 06:40 PM
TRENDSETTLER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypa &raquo;</TD></TR><TR><TD CLASS="quote">Since when did any civic come with a b18 motor?!?
The EK chassis SiR is the Canadian version of the USDM Si. It's also powered by the same b16a2 as the USDM Si. </TD></TR></TABLE>
LOL
anyways...everyone pretty much already answered it for you
US b18c1= 10.0:1, 170hp
jdm b18c= 10.6:1, 180hp
and the ecu differences
Old Apr 12, 2003 | 12:08 AM
NiiS's Avatar
Default Re: Difference in GSR and SiR B18c? (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
The OBD1 JDM P72 ecu's facotry programming sucks *** too. If you get a JDM B18C-SiR/G engine either upgrade the ecu or use a stock US OBD1 P72 ecu.</TD></TR></TABLE>
Accurate info
Old Apr 12, 2003 | 01:01 PM
AudioXtremes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypa &raquo;</TD></TR><TR><TD CLASS="quote">Since when did any civic come with a b18 motor?!? </TD></TR></TABLE>
In the EDM a civic did come with a b18.
Old Jul 11, 2008 | 04:48 PM
VTi_b0i's Avatar
Default Re: Difference in GSR and SiR B18c? (AudioXtremes)
how could you tell if you have a b18c GS-R or SiR motor?
Old Jul 17, 2008 | 11:25 AM
94b16teg's Avatar
Default Re: Difference in GSR and SiR B18c? (VTi_b0i)
GSR is B18C1
SIR-G is just B18C
Old Jul 17, 2008 | 02:43 PM
projectTeG's Avatar
i swear that the b18c(jdm sirg had 10.4 compression)
Old Jul 17, 2008 | 02:59 PM
VTi_b0i's Avatar
so the motor i stamped b18c1? mines just stamped b18c, vtec kicks in at 4400rpm, but mine has a speed cut at 180km/h so im assuming its SiR but how would i know exactly?
Old Jul 17, 2008 | 03:47 PM
94b16teg's Avatar
Default Re: (VTi_b0i)
Im pretty sure only jdm ecus have speed cut also.
Old Jul 20, 2008 | 01:42 PM
LastGenEK's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">i swear that the b18c(jdm sirg had 10.4 compression)</TD></TR></TABLE>
In canada
Old Jul 20, 2008 | 01:43 PM
projectTeG's Avatar
Default Re: (LastGenEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LastGenEK &raquo;</TD></TR><TR><TD CLASS="quote">
In canada</TD></TR></TABLE>
i know that but people were saying its running 10.6. thats factor Usdm ITR compression
sleepery7
Jan 4, 2008 07:07 PM
Vtec Hart
May 7, 2007 08:32 PM
street95civic
Jul 6, 2005 09:08 PM
sam95teg
Apr 7, 2005 03:09 PM
Nikos
Aug 29, 2002 09:40 AM
