Fuel Pressure #'s?
Old Apr 10, 2003 | 10:04 AM
SCedGTP's Avatar
Default Fuel Pressure #'s?
Just want to know what you guys are running for fuel pressure. It seems like my buddies GSR turbo is running rich at 52 psi.
What do you guys usually run at?
Old Apr 10, 2003 | 10:18 AM
PhatOptimo's Avatar
Default Re: Fuel Pressure #'s? (SCedGTP)
It depends on the computer and if its chipped. I have my FPR set to 37-38 psi with vaccum line attached @ idle. I also have a mugen ECU chip.
Old Apr 10, 2003 | 10:46 AM
psi420's Avatar
Default Re: Fuel Pressure #'s? (Phat_Optimo)
Stock fuel pressure is 42psi with Vacuum attached.
Thats what I am running.
pills_PMD's Avatar
i run 38 psi w/ vaccum reference at idle. p28 tuned to 13.0:1 with hondata at WOT
Old Apr 10, 2003 | 11:15 AM
SCedGTP's Avatar
Default Re: Fuel Pressure #'s? (pills_PMD)
Damn all I know is he has a 10,000 rpm rev chip in a B16 ecu. At idle he is at 50-52 psi and I know when we rev it the pressure sky rockets to 60+. He has a type r in tank fuel pump and a BBK inline fuel pump running Accel 310cc injectors. Should we adjust the AEM regulator down to 42-45 psi at idle and see how she runs cuz right now at 5-6k rpm it shudders bad and clears up after a bit. I figured it must be flooding when the v-tec is kicking in at that rpm range.
Old Apr 10, 2003 | 11:29 AM
toooslow's Avatar
My car must be messed up... im runnin at 47psi vaccuum attached and 50 without. I dont understand how it can be soo high because everything in fuel system is stock. any suggestions besides FPR?
Old Apr 10, 2003 | 11:54 AM
psi420's Avatar
Default Re: Fuel Pressure #'s? (whiteinteg95)
This is from Helms Manual, Standards and Service Limits - SPECS
Fuel Pressure Regulator
OBDI Manual States
Pressure with regulator vacuum hose disconnected:
kPa (kgf/cm2, psi)
B18B1 - 275 - 324 (2.8 - 3.3 , 40 - 47)
B18C1 - 329 - 378 (3.35 - 3.85 , 48-55)
OBDII Manual States
kPa (kgf/cm2, psi)
B18B1 - 270 - 320, (2.8 - 3.3 , 40 - 47)
B18C1 - 329 - 378 (3.35 - 3.85 , 48 - 55)
B18C5 - 320 - 370 (3.3 - 3.8 , 47 - 54)
GsrIntegra789
Jun 4, 2008 04:00 PM
BoOsTeD C1
Jun 23, 2005 12:54 PM
slimcivic95
Oct 28, 2004 11:41 AM
TedR719
Sep 8, 2004 02:57 AM
