95 civic shifter cable problems
Old Apr 10, 2003 | 09:31 AM
ChrisAnF1892's Avatar
Default 95 civic shifter cable problems
ok it is my friends eclipse and the cable cam unhooked or something because it wont go out of netural and i justed wanted to know if anyone knew about shifter cables and how they setup
Modified by ChrisAnF1892 at 12:38 PM 4/10/2003
Old Apr 10, 2003 | 10:15 AM
zCivic's Avatar
Default Re: 95 civic shifter cable problems (ChrisAnF1892)
wrong forum but your civic doesn't have a shifter cable unless its an A/T which those are only 4speeds....M/T uses a shift linkage which are bars that connect to the tranny and the shifter lever check them make sure everything is still connect
Old Apr 10, 2003 | 11:41 AM
Default Re: 95 civic shifter cable problems (zCivic)
i said it was a civic so i could get some help and the only reason i didnt know that they weren't cable and were hydrolic is cause there pieces of ashit so i dont mess with them
Old Apr 10, 2003 | 12:03 PM
zCivic's Avatar
well sorry you feel that way just letting you know... and If you would read you would see I suggested checking it at the tranny and the shift lever......you wanted help and you got it.....not starting a flame war good grief charlie brown......
Mishako129
Sep 6, 2012 03:14 PM
[713]
Jan 31, 2012 02:03 PM
honey mead
Aug 13, 2006 03:56 PM
8point6
16
Apr 25, 2005 02:45 PM
