help on installing radiator
If it is one that is made for your car then it is really easy all u have to do is drain it by pulling the cockpit out in the bottom of ur rad then there is only one bolt holding in on which is on top of the rad then take off hoses and pull out from top. if your installing a diffrent rad in u will have to just figure out how to mount it and thats all. It is a real easy process. You can handle it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NaughtyKnight666 »</TD></TR><TR><TD CLASS="quote">cockpit </TD></TR></TABLE>
Isn't the correct term ballcock or draincock or somethig.
