Harness Bar Adjustable fit
Harness Guide Bar Adjustable between 45-3/4 to 48 inches./ Fits the following vehicle definately: Integra (1990-1993) at the C-pillar (hatch area), Integra (1994-2001) at the factory seat belt shoulder pivot mounts and Del Sol (isn't easy, but it fits). Appears to fit 88-89 Civic Hatches and CRX's (I have not test fitted it, but the length is correct) Will NOT fit on 90-91 Hatches or 4drs due to door mounted and "mouse" shoulder belts. Includes mounting brackets. If you are in North Jersey, I'll do the install also. Otherwise I can walk you through it. Takes about 30 minutes to install.. More info available from:
http://www.ioportracing.com/Me...e=GB3
Asking $75 shipped, or can partially trade for STOCK 93-95 Civic EX/SI front sway bar and/or CRX HF front sway bar
Jeff
Jeff
You need to measure the distance between the bolts that hold the factory seat belt pivots to the upper part of the B-pillar. If it's between 45 3/4" and 48" it will fit..
Jeff
Jeff
just to clarify, this is a harness GUIDE bar. you should not mount your harnesses directly to this.
good luck on the sale. good price
-tony
-tony
fake mugen power
28
Apr 9, 2007 10:49 PM
