are you supposed to change your head bolts every time you take off the head?
Old Apr 9, 2003 | 09:57 PM
turbochic's Avatar
Default are you supposed to change your head bolts every time you take off the head?
just like the post says.... I am turboing my car (one in sig) and i am putting a new gskt, should i change the bolts? and if i do, should i get better than stock? or will stock be good? tia
Old Apr 9, 2003 | 10:08 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: are you supposed to change your head bolts every time you take off the head? (fmaxturbochic)
since it's off...might as well go with some extra security, especially with boost, with some ARP studs
Old Apr 9, 2003 | 10:43 PM
Luke J's Avatar
Default Re: are you supposed to change your head bolts every time you take off the head? (Emerika)
I have heard that the ARP's actually seat better after they have been torqued and used once, but regardless if you have ARP's you should get more than one use out of them.
Old Apr 9, 2003 | 10:46 PM
real9999's Avatar
Default Re: are you supposed to change your head bolts every time you take off the head? (Lucky925l)
You probably should. But many people don't, including most dealers, and seem to have no sealing problems. ARP's are a good choice.
Tom
Old Apr 9, 2003 | 10:51 PM
Luke J's Avatar
Default Re: are you supposed to change your head bolts every time you take off the head? (real9999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by real9999 &raquo;</TD></TR><TR><TD CLASS="quote">You probably should. But many people don't, including most dealers, and seem to have no sealing problems. ARP's are a good choice.
Tom</TD></TR></TABLE>
This is true, I used to work at a Ford dealership and we didn't replace the head-bolts when removing heads.
Old Apr 9, 2003 | 10:56 PM
turbochic's Avatar
how many times can you reuse the bolts?
Old Apr 11, 2003 | 01:33 PM
deepgreengsr's Avatar
at work we never change the bolts on normal cars. on race cars we usually replace then with ARP head Studs. Yes ther is a difference between bolts and studs. Studs are stronger. some cars come with studs factory most don't
Old Apr 11, 2003 | 01:41 PM
sweet's Avatar
Default Re: are you supposed to change your head bolts every time you take off the head? (deepgreengsr)
i've never reused OEM headbolts, but i've heard that if the bolts aren't damaged in any way and the motor will only see normal wear and tear, then reusing the original bolts isn't a problem.
i personally use ARP headstuds since they aren't too expensive. they torque better, hold up under heavy abuse and can normally be reused unless damaged.
IMO they are worth the $115, especially for a boosted or N2O injected motor.
Old Apr 11, 2003 | 04:14 PM
cajnatc's Avatar
Default Re: are you supposed to change your head bolts every time you take off the head? (sweet)
I rebuilt my civic for boost and I reused my stock studs and I haven't had any problems.
Old Apr 11, 2003 | 05:07 PM
wrXtian's Avatar
Default Re: are you supposed to change your head bolts every time you take off the head? (cajnatc)
i hear w/ the stock head bolts you will most likely blow a head gasket, but w/ the arp head studs you will most likely blow your block since they are so strong.. i duno how accurate the info is tho. this is just in the case where your engine is under so much stress it is actually going to go out.
Old Apr 11, 2003 | 10:33 PM
sleepinonacreeper's Avatar
Default Re: are you supposed to change your head bolts every time you take off the head? (DA9onBoost)
in the service manual it should give a length of your head bolts or put one against the other to see if some may be streched. if torqued properly they should be good for at least 3 times.
Old Apr 12, 2003 | 05:55 PM
AzG35's Avatar
Default Re: are you supposed to change your head bolts every time you take off the head? (sleepinonacreeper)
Stock headbolts are good for 3 torques. So 2 more times after you disassemble it the first time since its torqued once from the factory. I would replace them personally, ARP's are pretty cheap and reusable.
EFstyle
Nov 2, 2008 11:30 AM
youdontknowmeeither
Sep 26, 2006 06:38 AM
Fatty_1775
Feb 9, 2006 11:02 AM
wade
Jun 22, 2004 08:40 PM
iperez
Feb 11, 2004 07:21 AM
