For GSR owners with ITR cams and cam gears...
Old Apr 9, 2003 | 09:29 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default For GSR owners with ITR cams and cam gears...
im putting in my gears next weekend (have the cams in already) and before I go and tune anything I wanted to see what you all have - since they're relatively stock cams I figured it would only be a few degrees difference like +4 exhuast and -1 intake. what do you guys have your settings at?
Old Apr 9, 2003 | 09:40 PM
romeo619romeo's Avatar
Default Re: For GSR owners with ITR cams and cam gears... (dLo GSR)
keep it stock setting trust me
Old Apr 9, 2003 | 11:37 PM
BoM's Avatar
BoM
Default Re: For GSR owners with ITR cams and cam gears... (romeo619romeo)
u really need to dyno tune it.
try +2 intake -1 exhaust.
and if u like that keep it. dont' go too much.
Old Apr 10, 2003 | 12:17 AM
Default Re: For GSR owners with ITR cams and cam gears... (BoM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoM &raquo;</TD></TR><TR><TD CLASS="quote">u really need to dyno tune it.</TD></TR></TABLE>
yes, I understand that. i mentioned it in my post.
im just looking for a setting to throw on when i put the gears in. thanks for the #'s
Old Apr 10, 2003 | 12:42 AM
DA6GSR's Avatar
and if u like that keep it. dont' go too much.</TD></TR></TABLE>
that is the exact setting I ran my CTR cams at. That was after dyno tuning them.
Old Apr 10, 2003 | 12:52 AM
Mr.Integra's Avatar
A good range would be
Intake: 0 to +4
Exhaust: 0 to -2
Old Apr 10, 2003 | 02:31 AM
BoM's Avatar
BoM
Default Re: For GSR owners with ITR cams and cam gears... (Mr.Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Integra &raquo;</TD></TR><TR><TD CLASS="quote">A good range would be
Intake: 0 to +4
Exhaust: 0 to -2</TD></TR></TABLE>
thats better good. on stock compression thats the range you should stay with.
Old Apr 10, 2003 | 04:40 AM
split917's Avatar
do you guys have vafc or anything? reason i ask is because i was wondering if you kept the vtec cross over at 4400rpm or was it raised? i'm in the market for itr cams, but i'm still reasearching.
also, what valve springs are you using, stock itr?
Old Apr 10, 2003 | 04:41 AM
dip-set's Avatar
Default Re: For GSR owners with ITR cams and cam gears... (split917)
Old Apr 10, 2003 | 07:27 AM
dom93hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by split917 &raquo;</TD></TR><TR><TD CLASS="quote">do you guys have vafc or anything? reason i ask is because i was wondering if you kept the vtec cross over at 4400rpm or was it raised? i'm in the market for itr cams, but i'm still reasearching.
also, what valve springs are you using, stock itr?</TD></TR></TABLE>
Bump
I'd like to know too.
Old Apr 10, 2003 | 08:06 AM
acatak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dLo GSR &raquo;</TD></TR><TR><TD CLASS="quote">im putting in my gears next weekend (have the cams in already) and before I go and tune anything I wanted to see what you all have - since they're relatively stock cams I figured it would only be a few degrees difference like +4 exhuast and -1 intake. what do you guys have your settings at?</TD></TR></TABLE>Usually you want more top end so you want to advance the intake and retard the exhaust
Old Apr 10, 2003 | 08:08 AM
Malice's Avatar
New User
Default Re: For GSR owners with ITR cams and cam gears... (acatak)
i had itr cams a while back. before i tuned them, i advanced the intake cam to +2 and left the exhaust cam at 0
Old Apr 10, 2003 | 08:13 AM
obd2gsr's Avatar
I'd try +2 intake
-1 exhaust
and then wait until you get it dyno tuned before "trying" anymore adjustments.
Old Apr 14, 2003 | 04:59 AM
split917's Avatar
anyone that would like to answer?
Old Apr 14, 2003 | 08:15 AM
Malice's Avatar
New User
anyone that would like to answer?</TD></TR></TABLE>
vafc is a must for aftermarket cams. if ya dont have one, you'll get a alittle dip in power in the lower rpms. u'd wanna raise the vtec to at least 4800. when i had itr cams, mine were tuned at 5100
Old Apr 14, 2003 | 09:09 AM
EJ8 Kenobi's Avatar
Default Re: For GSR owners with ITR cams and cam gears... (MaliceGSR)
i believe the vtec point on ITRs are at somewhere close to 5000, give or take a hundred. someone correct me if i'm wrong.
Old Apr 14, 2003 | 09:21 AM
P1mpSlap's Avatar
Do you guys still run the stock GSR vlavetrain with the ITR cams..?
Old Apr 14, 2003 | 09:37 AM
acatak's Avatar
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys still run the stock GSR vlavetrain with the ITR cams..?</TD></TR></TABLE>I am running stock gsr valvetrain, but to notice the full power of the itr cams, you would need to upgrade your valvetrain
JDAMC
Mar 8, 2007 05:14 AM
accord-h22
Feb 23, 2007 03:49 PM
RC's ride
Dec 11, 2005 03:52 PM
PaulB
Dec 23, 2003 09:16 PM
slowacura
Dec 18, 2003 09:13 PM
