Installing the "bitch pin" (shift linkage at tranny), Best way?
Old Apr 9, 2003 | 08:46 PM
Fuster_Cluck's Avatar
Default Installing the "bitch pin" (shift linkage at tranny), Best way?
I went to install the shift linkage today on my Eg / GSR hybrid and the damn thing is about half-way in. I used the old pin I took out the Cx since it looked exactly like the new GSR one I bought and was NOT mushroomed from when I beat it out with the socket extension.
Anyhow, it's a little f**ked (mushroomed) from where I tried to beat it in. I'm probably going to remove it in the morning and if you guys have any tips install the new pin afterwards.
It was a "bitch" getting it out, but getting it back in seems to be a "*****"
I'm just hoping someone has done this enough times and maybe has a trick you can share
Thanks!
PS <> Will I ever have to remove this thing? Yeah, I'm sure if I blow the motor or the tranny gets ruined I'll have to remove the shift linkage. But, I've read where people have pulled the motor with the shift linkage attached. Should I just beat the damn thing in if worst comes to worst?
Old Apr 9, 2003 | 09:14 PM
pbomers's Avatar
Default Re: Installing the "bitch pin" (shift linkage at tranny), Best way? (Hybrid93Hatch)
OMG...i thought my friends and i were the only people that called it the "bitch pin."
only advice i can give ya is try and find a punch that is the right size. my dad happen to have one that was perfect.
PauL
Old Apr 9, 2003 | 09:17 PM
Malachi's Avatar
got mine out with a punch and a 15 lbs sledge hammer.
Old Apr 9, 2003 | 09:23 PM
Default Re: Installing the "bitch pin" (Malachi)
Helms (or I read it somewhere) says an 8mm punch. I'm going to pick one up in the morning. Does this fit perfectly with the pin which will NOT mushroom the end?
I've got the 4lb hammer ready to go
Old Apr 9, 2003 | 09:25 PM
drunknbass's Avatar
Default Re: Installing the "bitch pin" (Hybrid93Hatch)
if you have the right size punch (honda actually has a special little tool) the pin pops out easy as pie
Old Apr 9, 2003 | 09:28 PM
Default Re: Installing the "bitch pin" (drunknbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunknbass &raquo;</TD></TR><TR><TD CLASS="quote">if you have the right size punch (honda actually has a special little tool) the pin pops out easy as pie</TD></TR></TABLE>
Actually, I was asking if there are any tricks to put it back in.
I've already took it out when I removed the Cx motor. Need to put it in the GSR
Old Apr 9, 2003 | 09:31 PM
Nameless RB26's Avatar
There isn't really any tricks, maybe some WD-40, which is what I used. Once you get it started however, you can back off and just wale on it.
Old Apr 9, 2003 | 09:38 PM
Default Re: Installing the "bitch pin" (Nameless EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">There isn't really any tricks, maybe some WD-40, which is what I used. Once you get it started however, you can back off and just wale on it.</TD></TR></TABLE>
Probably good advice there
I'm going to soak it from the top side and let it drip down good and get it all lubed then just pound that bitch in there with the sledge and an 8mm punch
Old Apr 9, 2003 | 09:54 PM
BoM's Avatar
BoM
i used a threaded skrew, and just hammered it in and out.
took like 3 swings with a hammer.
Old Apr 9, 2003 | 10:15 PM
careawholelot's Avatar
Default Re: Installing the "bitch pin" (BoM)
damn i hate the bitch pin. it was the hardest part of my swap i could not get that **** out. but getting it in was pretty easy for me, i just held it by to of my fingers and carefully hit it with a hammer to were it would stay in the hole without me using my fingers then i got a piece of 2x4 and laid it flat on the pin and just beat it 2-3 times with a hammer went in like a charm.
Old Apr 9, 2003 | 10:24 PM
X2BOARD's Avatar
When you do it enuff times... it even becomes easy with a phillips head...lol
An 8mm punch is what to use to make it simple... and you should be able to do it w/ a regular hammer, as long as the car is high enuff to get a decent back swing.
Step #1) Coat it lightly w/ some oil
Just get it wedged in and tap it with the broadside of the hammer.
You should only need the punch once it's 1/2 way in or more.
A trick ? Once wedged in, you can tap the edges of the pin to help it along, but you gotta be accurate.
X2 (Bitch Pin Masta)
Old Apr 9, 2003 | 10:33 PM
Downey's Avatar
hammer and a center punch works well for me.
Old Apr 9, 2003 | 11:08 PM
Shawn C's Avatar
In The Garage
Default Re: Installing the "bitch pin" (Downey)
ha ha, i cussed that damn thing until i threw it into the neighbor's yard. i ended up using a bolt and locknut w/loctite (red) that was the perfect diameter. i also pulled the engine with the linkage attached. it was a *****. i had to jack the front of the car up like 2 ft, then pull out the engine. i felt like such a dumbass. now all engines go in from underneath. 2 strong people can lift up the front of a honda without an engine in it. go get some and good luck
Old Apr 10, 2003 | 08:13 AM
ZCHF's Avatar
Default Re: Installing the "bitch pin" (22lbGS-R)
i stuck a fireplace poker(you know, the one with the pointy end and little curvinglip) down the top of my engine and hit it with a sledgehammer and it bent the **** out of the poker but still came out. Victory
Old Apr 10, 2003 | 10:38 AM
Tony Starks's Avatar
Default Re: Installing the "bitch pin" (ZCHF)
Get underneath the car and use a phillips head to poke at the pin and use hammer to beat the **** out of the screwdriver. This was the most difficult part of my swap.
Old Apr 10, 2003 | 11:10 AM
Default Re: Installing the "bitch pin" (Tony Starks)
Here's how it sits as of now. I lubed it up with WD40 and hit it a few times with a sledge hammer and it did NOTHING!
I'll try again Saturday when I plan to finish the swap and fire the motor up.
Old Apr 10, 2003 | 11:26 AM
94HybridEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">PS &lt;&gt; Will I ever have to remove this thing? Yeah, I'm sure if I blow the motor or the tranny gets ruined I'll have to remove the shift linkage. But, I've read where people have pulled the motor with the shift linkage attached. Should I just beat the damn thing in if worst comes to worst?</TD></TR></TABLE>I removed my old D16 and tranny with the linkage attached. It wasn't a pain at all. Shouldn't be too hard installing a motor with the linkage attached.
Old Apr 10, 2003 | 12:45 PM
fcuked's Avatar
Default Re: Installing the "bitch pin" (94HybridEX)
FYI
I've done 3 swaps already and i never took the shifter linkage out. Take one of the linkages out, the easier one nad it will give you more slack. Also if you are doing a swap you can always put the motor under the car and put it up or when dropping it in you can still clear the engine bay with the shifter linkage as long as one of them is disconnected.
Old Apr 10, 2003 | 12:54 PM
rainmanEK's Avatar
big strong guy
Default Re: Installing the "bitch pin" (Junior.)
1/4" Punch Works Great!
Also Any 1/4" Bolt can work too If you want to go cheap!
Make sure you hold hand on back side, Being the PIN can Fly out on the last hit and you WIll NEVER FIND IT!!
Eric
Old Apr 10, 2003 | 01:27 PM
youngkow's Avatar
Best way to put it in is to use a channel lock plier. As long as its big enough, you'll get good leverage to squeeze it in. If you can't picture it, I'll try and draw a pic. Let me know how it works out.
Old Apr 28, 2003 | 02:57 PM
@irborne's Avatar
i hate that "bitch pin" more than anything. i'll pull the motor w/ one main linkage arm. arrg.
Old Apr 28, 2003 | 03:14 PM
RSZero1's Avatar
Default Re: Installing the "bitch pin" (@irborne)
you can also use a 12mm bolt, like from a throttle body, and tap it in or out with one, fits perfect. When pounding it back in, make sure you have a thin screwdriver or something you can push thru the pin to make sure it is lined up before you start pounding away, sometimes the linkage will move a little and you think it's going in, but it's really just hitting next to the hole in the linkage...
Old Apr 28, 2003 | 03:17 PM
transmission11's Avatar
if its mushroomed, shave a little of the mushroomed part off till it fits nicely
Old Apr 29, 2003 | 02:09 PM
madman604's Avatar
Default Re: Installing the "bitch pin" (transmission11)
here's a tip. make sure the holes line up sounds stupid, but i did it
after teh first whack it moved, everyother wack just damaged the fit more
honda shoulda just stuck a fuggin bolt in there
Old Apr 29, 2003 | 02:18 PM
b2023's Avatar
use a punch tool that will be the same width of the pin.... or u can use the bolt that is used for hooking the header and cat-converter together.. it s the same size as the pin.
