b17 head questions
Old Apr 9, 2003 | 08:14 PM
spoon063's Avatar
Default b17 head questions
i'm tryin to build a vtec head up... i got a deal with a b17 (92-93) gsr head, what can i do for valve springs, cams, etc... are they same as b16a parts? i'm tryin to build a strong all motor, can i do it with this head ? any help would be appreciated
Old Apr 9, 2003 | 08:37 PM
mr.beeks's Avatar
Default Re: b17 head questions (spoon063)
they are like b16 heads
so thats how they get treated!!!
but they are much easier to use for a ls/vtec set up
Old Apr 9, 2003 | 08:49 PM
romeo619romeo's Avatar
Default Re: b17 head questions (FRANCISCO FLORES)
umm port and polish dual valve springs square combustion chamber oversize valves ctr cams cam gears replace the oil rail to the new ones and thats about it
Old Apr 9, 2003 | 08:52 PM
YumVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRANCISCO FLORES &raquo;</TD></TR><TR><TD CLASS="quote">they are like b16 heads
how is a b17 head much easier to use than a b16 head in a ls/vtec setup? i'm not trying to flame, just extremely curious as i've never heard that claim before.
Old Apr 9, 2003 | 10:51 PM
DA6GSR's Avatar
Default Re: b17 head questions (YumVTEC)
I would think it harder to use then B16 head in the fact that without modifications the only Intake manifold you can use is the one from the B17 as opposed to with B16 you can use the B16 and B18C intake manifold.
Old Apr 9, 2003 | 10:59 PM
Default Re: b17 head questions (SloSpeedRacrGSR)
im guessing hes refering to the grey plug i guess
Old Apr 9, 2003 | 11:05 PM
X2BOARD's Avatar
Default Re: b17 head questions (romeo619romeo)
Lol... B17 head is just as hard to do LSVT as other heads.... don't know what he's talking about.
B17 is a good head/i/m, if you can't afford dual valve springs (read ITR), definitely go w/ at least new springs and fresh valve seals. Also newer GSR cams have a more aggressive lobe, but I don't know if you'd get the full potential on a stock b16 or b17 ecu. (What ecu ARE you gunna use ?)
X2
Old Apr 10, 2003 | 09:20 AM
spoon063's Avatar
Default Re: b17 head questions (X2BOARD)
i'm planning on rebuilding it totally, i'm just curious as what to get as far as b16 parts? or b18 parts ? i'm gonna be runnning a chipped p28 with vafc, i wanted to get toda c's, toda springs, retainers, je pistons, eagle rods, etc...
Old Apr 10, 2003 | 09:55 AM
ill phil's Avatar
Well, most of the valvetrain parts you will find will say they are for B16/B18C VTEC heads and non-specific. That's how Toda sells theirs, you would be fine buying valvesprings and retainers for the B16 head.
http://www.todaracing.com
To the guy who was talking non-sense about the intake manifolds.....the b16 and b17 heads are the same casting- they could use the same manifolds. And by b18c manifold on a b16 head i hope you are not referring to a b18c1 manifold
Old Apr 10, 2003 | 05:50 PM
spoon063's Avatar
Default Re: b17 head questions (ill phil)
nah not ls itm, either skunk2 or ITB just all depends on funds i guess. what do you think about toda c's as far as goin in the b17 ?
Old Apr 10, 2003 | 06:34 PM
ill phil's Avatar
Better have a high compression bottom end to make any real power, and someone to tune it well. They are really aggressive cams. Same lower lobes as Toda B's just more aggressive VTEC lobe.
Old Apr 11, 2003 | 12:25 PM
spoon063's Avatar
as far as ive looked so far i want possibly arias 12:1, eagle rods, rings, new bearings... do you know as far as which head studs i use ? gsr or ls ? oh and by the way i traded the b17 for a 00'gsr head so i dont have to worry about any fitting problem. while i'm at it which head gasket do i use ? any help on hte subject of LSVTEC would be greatly appreciated.
Old Apr 11, 2003 | 12:30 PM
YumVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon063 &raquo;</TD></TR><TR><TD CLASS="quote">as far as ive looked so far i want possibly arias 12:1, eagle rods, rings, new bearings... do you know as far as which head studs i use ? gsr or ls ? oh and by the way i traded the b17 for a 00'gsr head so i dont have to worry about any fitting problem. while i'm at it which head gasket do i use ? any help on hte subject of LSVTEC would be greatly appreciated.</TD></TR></TABLE>
why would you trade a b17 head which uses the same casting as a b16 or ITR head, for a 00 gs-r head? Now your choices for certain parts are limited. Bad choice, reverse it if you can.
Old Apr 11, 2003 | 12:37 PM
spoon063's Avatar
i just figured instead of replacin valve seals and possiblky valvesw right away, plus the b17 was missin some parts
Old Apr 11, 2003 | 01:22 PM
YumVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon063 &raquo;</TD></TR><TR><TD CLASS="quote">i just figured instead of replacin valve seals and possiblky valvesw right away, plus the b17 was missin some parts</TD></TR></TABLE>
k, now THAT makes more sense.
B-JUSTINE
May 26, 2006 02:38 PM
2gen_tegs_rule
Feb 6, 2006 12:29 PM
DAintegra
Dec 1, 2004 02:37 PM
LSHatchback
22
Jun 12, 2003 12:01 PM
Sassafrass
Mar 3, 2003 07:46 AM
